FOSI AUDIO BT30D Class D 2.1 Amplifier
The Fosi Audio BT30D is a 2.1-channel Class D amplifier capable of developing 2x50W + 100W power thanks to two TI TPA3116D2 amplifier chips. It also features Bluetooth 5.0 functionality for stable, high-quality wireless reception. The front panel features no fewer than 5 potentiometers.
Reference : 19007
109,00 €tax incl.
90,83 € tax excl.
FOSI AUDIO BT30D Class D 2.1 Amplifier Bluetooth 5.0 2xTPA3116D2 2x50W + 100W 4 ohm
Photo of FOSI AUDIO BT30D amplifier
The Fosi Audio BT30D is a 2.1-channel Class D amplifier capable of developing 2x50W + 100W power under 4 ohm thanks to two TI TPA3116D2 amplifier chips. It also features Bluetooth 5.0 functionality for stable, high-quality wireless reception. The front panel features no fewer than 5 potentiometers. The first three are for volume control as well as bass and treble equalization, while 2 others offer subwoofer frequency cutoff and subwoofer volume control. The rear panel features an RCA input, a speaker terminal output and two subwoofer outputs: one for passive subwoofer and one for active subwoofer. This small BT30D amplifier is ideal for setting up a 2.1-channel home theater system and enjoying immersive bass.
FOSI AUDIO BT30D: Two TI TPA3116D2 chips
Inside the Fosi Audio BT30D amplifier are two TI TPA3116D2 amplifier chips, providing 2x 50W + 100W power at 4 ohms. That's a comfortable reserve of power for providing a 2.1-channel system.
Photo of TI TPA3116D2 chipsPhoto of TI TPA3116D2 chips
Fosi Audio BT30D Bluetooth fonctionality
FOSI AUDIO BT30D: Bluetooth functionality
In addition to its RCA input, the BT30D features a Bluetooth 5.0 reception chip, enabling you to use a phone or tablet to stream audio remotely.
Fosi Audio BT30D overview
FOSI Audio BT30D interface diagram
1Power button
2Input mode LED indicator
3Subwoofer volume control
4Subwoofer frequency cutoff
5Treble equalization
6Bass equalization
7Volume control
8Bluetooth antenna
9RCA input
10Active subwoofer output
11Speaker terminals
12Active subwoofer output
13Power supply 12V-24V DC
Product typeAmplifiier
Channels2.1
Amplification chipTI TPA3116D2
Inputs1x RCA stereo
Bluetooth
OuputsSpeaker terminals
1x Passive subwoofer output on speaker terminal
1x Active subwoofer output
Ouput power2x 50W + 100W
THD≤ 0.04%
SNR≥ 98dB
Frequency response20Hz-20kHz(±3dB)
Input sensitivity≤ 280mW
Termination impedance2-8 ohm
Subwoofer cutoff frequency20-200Hz
Bluetooth range15m unobstructed
Power supply12V-24V
Dimensions118 x 132 x 35mm
Package1x Fosi Audio BT30D
1x 24V DC 4.5A power adapter with power cable
1x Bluetooth antenna
OutputSpeaker terminal
Channel2.1
Amplifier chipTPA3116D2
Power (W)50.0
The Fosi Audio BT30D is a 2.1-channel Class D amplifier capable of developing 2x50W + 100W power thanks to two TI TPA3116D2 amplifier chips. It...
