FOSI AUDIO DA-2120C Amplifier Class D TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Black
With the DA2120C, Fosi Audio offers a versatile and affordable Class D amplifier. Its amplification stage allows it to deliver a power of 2x90W under 4Ω, and this with a high efficiency.
4.0 / 5
Reference : 17576
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 29-05-2025.
Fosi Audio DA-2120C
FOSI AUDIO DA-2120C Amplifier FDA Class D TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Black
With the DA2120C, Fosi Audio offers a versatile and affordable Class D amplifier. Its amplification stage allows it to deliver a power of 2x90W under 4Ω, and this with a high efficiency specific to this type of amplification. Its integration will be easy within the vast majority of audio systems thanks to its complete connectivity, consisting of a USB-B port, Toslink optics and coaxial but also stereo RCA. The DA2120A also includes a QCC3031 Bluetooth receiver, allowing you to stream your music remotely, from a smartphone or tablet for example. Support for the aptX HD transmission codec then makes it possible to enjoy quality sound reproduction wirelessly. On the output side, in addition to its speaker terminals, the DA2120A offers a subwoofer output, offering the possibility of mounting a 2.1 audio system.
LED Display screen and remote control
In addition to these good performances, the DA2120C has a screen displaying data related to audio track playback as well as a remote control that can adjust the treble and medium as well as the bass but also select different EQ modes.
1Bluetooth antenna connector
2USB-B input
3Optical toslink input
4Coaxial input
5RCA stereo input
6subwoofer output (RCA)
7HP outputs
8Power supply connector (DC 24V - 36V)
Product typeAmplifier
Amplification typeClass D
InputsBluetooth 5.0
1* USB-B
1* Optical Toslink
1* Coaxial
1* Stereo RCA
OutputsSpeaker terminals
1* subwoofer output (RCA for active sub)
Bluetooth receiverQCC3031
USB InterfaceCM6642
Amplification ChipTI TAS5352A
Audio processorTI TAS5508
Dac ChipAmerican cirrus CS8422
Output power2*90W @ 4Ω (1% THD / 32V)
2*120W @ 4Ω (10% THD / 32V)
Supported sampling ratesPCM 24bit 192kHz
Systeme compatibilityWindows XP / 7 / 8 /10
Mac
Linux
Supported Bluetooth CodecsAAC, SBC, aptX HD
Input sensitivity0.775V
THD≤ 0.01%
SNR≥ 105dB
Frequency range20Hz - 20kHz (±1 dB)
Termination impedance2 - 8
Tone controlBass / Treble via remote control
Power supply24 - 36V DC
Dimensions (L*P*H)180*130*38mm
Chassis materialAluminium
Package1* Fosi Audio DA2120C
1* Power supply delivered (DC 32V 5A)
1* Remote control
1* USB cable
1* Optical cable
OutputSubwoofer
OutputSpeaker terminal
Channel2.1
Channel2 (Stereo)
Amplifier chipTAS5352A
Power (W)90.0
Remote ControlYes
Tres bon rendu.
Couplé avec des Spektor2 (Dali)
J'étais méfiant envers ces FDA.
Très bonne scène en Optique; du Volume et des basses que je suis obligé de moduler en fonction des enregistrements.
J'avais peur de basses électroniques, d'un rendu des aigus trop froid, trop clean-ique. Non, Impeccable.
Possible qu'a un volume au-delà de 65, ça sature. (suivant qualité de l'enregistrement) Je monte guère au delà des 40.
je ne me sers pas du Bluetooth; RCA décevant.
L'USB est surprenant en précision. L'optique: parfait (câble fourni relié à mon ordi)
This review has been posted for FOSI AUDIO DA-2120C Amplifier Class D TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Black
With the  DA2120C , Fosi Audio offers a versatile and affordable  Class D amplifier . Its amplification stage allows it to...
