The Fosi Audio TP-03 mono + subwoofer amplifier is compact but efficient. It features an ST TDA7498E amplifier chip, delivering 220W of power at 4 Ohms. It features two operating modes selectable on the front panel, allowing you to choose between powering an active or passive subwoofer, in which case you'll need to set the frequency potentiometer (FREQ) to "Direct". Or it can power a passive speaker, in which case you'll need to set the frequency potentiometer to "Tone High". Note also that the latter allows adjustment of the 20Hz - 300Hz low-pass filter. Simple and effective, this subwoofer amplifier also features a phase inversion option, enabling it to drive a large number of subwoofers available on the market. A 24V DC 4.5A power supply is supplied.
Fosi Audio has chosen to integrate an ST TDA7498E amplifier chip for its TP-03 amplifier. This STMicroelectronics chip is a Class D amplifier. In particular, it features a "Standby and mute" function, allowing golden silence, devoid of the slightest background noise when no signal is sent to the Fosi TP-03.
1 | Power Switch |
2 | Power Light |
3 | Phase Adjustment |
4 | Subwoofer (FREQ adjust) & Full frequency output |
5 | Volume Adjustment |
6 | RCA Input |
7 | 3.5mm AUX Input |
8 | Speaker Output |
Product type | Mono + Subwoofer amplifier |
Amplification chip | ST TDA7498E |
Input | 1x RCA input 3.5mm Jack |
Output | 1x Bornier enceintes |
Output power | 220W |
Output impedance | 4Ω |
Input sensitivity | ≤ 0.2mV |
Frequency response | 20Hz - 20KHz (±3db) |
Bass frequency range | 20Hz - 300Hz |
Total harmonic distortion (THD) | ≤0.03% |
Signal-to-noise ratio (SNR) | ≥ 106dB |
Power supply range | 19V - 32V DC |
Net weight | 1kg |
Dimensions | 12.7 x 7.42 x 2.54 cm |
Color | Black |
Package | 1x Fosi Audio TP-03 1x Power Adaptter 24v 4,5A 1x User Manual |
Input | Jack 3.5mm |
Input | RCA |
Output | Speaker terminal |
Color | Black |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | TDA7498E |
Power (W) | 220.0 |
Remote Control | No |
