The HT4S from Fosi Audio is a compact integrated amplifier with 5 channels capable of delivering 30W each thanks to several TPA3116 amplifier chips.
For even greater flexibility, the HT4S can alternate between 5.0 and 4.1, allowing you to use it in a 5-speaker full-range configuration or reserve one of the channels for a passive subwoofer. Furthermore, the HT4S has a pre-out so you can connect an active subwoofer and enjoy a 5.1 surround configuration.
Finally, for even more versatility, the HT4S offers a Bluetooth input in addition to the Toslink optical input and the 3.5mm jack auxiliary input. As an aesthetic touch, the light strip on the front of the device changes colour according to the input used: blue for Bluetooth, orange for the auxiliary input and red for the optical input.
The subwoofer function of the Fosi Audio HT4S can be activated via a selector switch for a 4.1 configuration using the speaker terminals. FLAT mode allows the 5 terminals to output the full frequency range, while SUB mode applies a crossover to the 5th terminal to output a 20Hz-300Hz signal for coupling a passive subwoofer. Use of the FLAT mode, meanwhile, offers the possibility of a 5.1 system using an active subwoofer with the 3.5mm pre-out jack output.
A LED indicator lets users quickly know which input source is being used:
The Fosi Audio HT4S is ideal for home cinema and Hi-Fi set-ups, but can also be used with up to 5 bass shakers/exciters for an immersive gaming setup.
On the front panel of the Fosi Audio HT4S, you'll find a relatively comprehensive control interface for adjusting bass and treble tones, overall volume, and also the volume of a passive subwoofer.
| Specifications | |
| Product type | 5-channel integrated amplifier |
| Amplification type | Class D |
| Amplification chips | TPA3116 |
| Number of channels | 5.0 4.1 |
| Inputs | 1x Aux Jack 3.5mm 1x Optical Toslink Bluetooth |
| Outputs | 1x Pre-out 5x Speaker terminals |
| Output power | 5.0 : 5x30W 4Ω 4.1 : 4x30W + 1x60W 4Ω |
| Output impedance | 4-8Ω |
| Crosstalk | 79dB |
| Total harmonic distortion (THD) | 0.03% |
| Signal-to-noise ratio (SNR) | 88dB |
| Dynamic range | 89dB |
| Noise floor | 350µV |
| Frequency response | 20Hz - 20kHz (±0.5dB) |
| General | |
| Power supply voltage | 110V - 240V AC |
| Dimensions | 284 x 178 x 100mm |
| Weight | 1.8kg |
| Color | Black |
| Package | 1x Fosi Audio HT4S 1x Power cord 1x Bluetooth antenna 1x 3.5 mm Jack cable 1x Remote control |
| Input | Bluetooth |
| Input | Optical |
| Input | Jack 3.5mm |
| Output | Jack 3.5mm |
| Output | Speaker terminal |
| Color | Black |
| Channel | 5 |
| Class | Class D / T |
| Amplifier chip | TPA3116 |
| Power (W) | 30.0 |
| Power (W) | 60.0 |
| Remote Control | Yes |
