By buying this product you get 64 loyalty points
Amplifier Class AB Phono MM 2x65W 4Ω
Keces offers with its E40 a beautiful amplifier operating in Class AB with 4 transistors. It is capable of delivering a power of 2x65W under 4Ω with a beautiful musicality. It also incorporates a precise motorized volume controller with volume level memory function. On the connectivity side, the E40 features a USB-B input as well as two stereo RCA inputs and a MM phono input to connect a vinyl turntable. For the outputs, there are of course speaker terminals, but also a pre-out RCA output allowing the connection of a subwoofer, as well as a headphone output on 3.5mm jack on the front. The device is delivered with a remote control for a remote control.
Product type | Amplifier |
Amplifier type | Class AB |
Inputs | 1x USB-B 2x Stereo RCA 1x Phono MM 47kΩ input |
Outputs | Speaker terminals 1x Pre-out stereo RCA output (possibility to connect a subwoofer) 1x Jack 3.5mm headphone output |
Output power | 2x65W @ 4Ω 2x50W @ 8Ω |
Frequency response | 5Hz - 100kHz |
THD+N | < 0.008% @ 1kHz, A-Weighting |
THD+N phono output | < 0.02% @ 1kHz, A-Weighting |
SNR | 110dB @ A-Weighting |
SNR phono output | 82dB @ A-Weighting |
USB transmission mode | Asynchronous |
Max USB sampling rate | PCM 16bit 48kHz |
Supply voltage | 110-120V 60Hz 220-240V 50Hz |
Consumption | 180W |
Housing material | Aluminum 3mm |
Dimensions | 220 x 220 x 66mm |
Weight | 4kg |
Color | Black |
Input | USB |
Input | Phono |
Input | RCA |
Output | Jack 3.5mm |
Output | Speaker terminal |
Output | RCA |
Color | Black |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 65.0 |
Remote Control | Yes |
