By buying this product you get 119 loyalty points
The NAD C379 amplifier benefits from a HybridDigital UcD digital amplifier module and an ESS ES9028 DAC chip for superb performance. It can deliver up to 2x80W of power at 4Ω or 8Ω, and supports high-resolution streams up to 32bit 384kHz PCM. Added to this are numerous features and extensive connectivity, making it a versatile and complete integrated amplifier:
The NAD C379 delivers up to 2x 80W of output power at either 4Ω or 8Ω impedance. This is made possible by its HybridDigital UcD amplification technology, NAD's customized version of the Hypex UcD technology. This technology offers a high level of efficiency with sound reproduction benefiting from a minimum of noise and distortion. Overall, sound quality is optimal, precise and subtle.
The NAD C379 incorporates an ESS ES9028 DAC chip, enabling it to support high-resolution sampling rates up to 32bit 384kHz PCM. This digital-to-analog conversion chip offers a beautiful dynamic range and ultra-low distortion for the most pleasant listening experience.
A Bluetooth receiver-transmitter module available within the NAD C379 enables users to enjoy high-quality wireless listening via a smartphone, thanks to support for high-definition codecs such as aptX HD. But it's also possible for the NAD C379 to pair with wireless headphones or earphones thanks to bi-directional Bluetooth.
Two MDC2 racks are available on the rear panel of the NAD C379. These slots allow modules to be added to the amplifier to bring it new functionalities. In particular, an MDC2 BluOS-D module (sold separately) can be implemented to add Wi-Fi, Airplay 2, two-way Bluetooth, multiroom and Dirac Live calibration functions. In addition, the BlueOS application is able to access a number of online streaming services: Tidal, Deezer, Qobuz, Amazon Music, Spotify, etc.
On the front of the NAD C379, you'll find an attractive LCD screen that provides access to the unit's various settings for simple, efficient navigation. In addition, an infrared remote control enables remote control of the device, for a highly practical user experience.
The NAD C379 is an integrated amplifier with extensive connectivity. These include an HDMI eARC input for retrieving the sound signal from a TV, and a phono input compatible with MM cells, as well as Toslink optical, SPDIF coaxial and RCA line inputs. Outputs include an RCA Pre-out, a subwoofer output and two pairs of speaker terminals. These two pairs of speaker terminals offer the possibility of using two separate pairs of speakers or a bi-wiring configuration. All in all, the NAD C379 offers a wide range of possibilities for connection, making it the centerpiece of your HiFi system.
| 1 | 2x MDC2 rack |
| 2 | Bluetooth antenna |
| 3 | Reset |
| 4 | USB service port |
| 5 | RS332 |
| 6 | IR input / output |
| 7 | Trigger 12V input / output |
| 8 | Stereo / Mono mode (Bridge) |
| 9 | HDMI eARC input |
| 10 | 2x Optical Toslink input |
| 11 | 2x Coaxial input |
| 12 | Phono input (MM) |
| 13 | 2x RCA line input |
| 14 | Pre-out RCA output |
| 15 | Subwoofer output |
| 16 | 2x Speaker terminals |
| 17 | Power switch |
| 18 | AC power supply |
| Specifications | |
| Product type | Integrated amplifier |
| Amplification | HybridDigital UcD |
| DAC chip | ES9028 |
| Inputs | 1x HDMI eARC 2x Optical Toslink 2x Coaxial 1x Phono MM 2x Line RCA Bluetooth |
| Outputs | 2x Speaker terminals 1x RCA pre-out 1x Subwoofer output 1x 6.35mm jack headphones output Bluetooth |
| Other connectors | 1x Trigger input 1x Trigger output 1x IR input 1x IR output 2x Rack MDC2 USB-A service port RS232 |
| LCD screen | |
| Supported sample rates | PCM up to 32bit 384kHz 24bit 192kHz via coaxial and optical inputs |
| Bluetooth 5.0 | Bidirectionnal |
| Supported Bluetooth Codecs | SBC, AAC, aptX HD |
| Line input/HP output specification | |
| Output power | 2x80W @ 4Ω and 8Ω |
| Bridge mode output power | 300W @ 8Ω |
| THD | < 0.03% (250mW Ω 120W, 8Ω and 4Ω) |
| SNR | > 85dB (A-Wt, input 500mV, ref. 1W @ 8Ω) |
| Frequency response | 20Hz - 20kHz ±0.3dB |
| Channel separation | > 90dB (1kHz) > 75 dB (10kHz) |
| General | |
| Power supply | 100-240W 50/60Hz |
| Color | Black |
| Dimensions | 435 x 100 x 410mm |
| Net weight | 9.04 kg |
| Package | 1x NAD C379 amplifier 1x Remote control 1x Power supply cable |
| Input | Optical |
| Input | RS-232 |
| Input | SPDIF |
| Input | Bluetooth |
| Input | HDMI ARC |
| Input | RCA |
| Output | Subwoofer |
| Output | RCA |
| Output | Jack 6.35mm |
| Output | Bluetooth |
| Output | Speaker terminal |
| Color | Black |
| Channel | 2 (Stereo) |
| Channel | 1 (Mono) |
| Class | Class D / T |
| Amplifier chip | N/A |
| Power (W) | 300.0 |
| Power (W) | 80.0 |
| Remote Control | Yes |
