By buying this product you get 139 loyalty points
The R610 by Ruark Audio is a multifunction amplifier designed to be the heart of your HiFi setup. In addition to delivering an output power of 2x75W, it also functions as a streamer and phono amplifier, with Bluetooth and HDMI ARC/eARC connectivity, ensuring total versatility in a highly elegant design.
Visually, the Ruark Audio R610 stands out with its refined wood finish. The front panel features a walnut grille and houses a stunning 12.7cm color TFT screen, displaying album covers and other information related to the content being played.
Beyond its aesthetic appeal, the R610 benefits from close attention to its technical specifications. It is powered by a modern switching power supply, providing optimized power lines to the motherboard, Burr-Brown DACs, and next-generation Class D amplifiers, ensuring a nominal output power of 75W per channel at 4Ω.
The R610 offers full connectivity and, thanks to its powerful processor, can handle audio streams up to PCM 32-bit 384kHz. With integrated internet radio, Spotify Connect, Tidal Connect, Apple AirPlay, and Google Cast, it acts as a network player, giving you easy access to all your favorite tracks, regardless of the platform. It is also Bluetooth-compatible, allowing you to play high-resolution music via the aptX HD codec.
Ready to support physical formats, the R610 includes a high-quality phono amplifier, allowing for the direct connection of a turntable. For CD enthusiasts, a USB port on the back enables easy connection of a CD player. Finally, the HDMI ARC/eARC connection offers an immersive home theater experience.
As a Ruark Audio product, the R610 comes with the brand's signature RotoDial remote control. This allows you to control your device remotely thanks to its touch-sensitive buttons and control wheel. Furthermore, since the remote is connected via Bluetooth, you don't need to aim at the device, so you can control the R610 from the comfort of your seat.
Product type | Connected amplifier |
Inputs | 1x Stereo RCA 1x Phono input 1x HDMI ARC/eARC 1x Optical Toslink 1x RJ45 1x USB-C |
Outputs | Speaker terminals 1x RCA line output 1x Subwoofer output |
Wireless connectivity | WiFi Bluetooth 5.1 |
Supported Bluetooth codecs | aptX HD / SBC / AAC / BLE / A2DP |
Compatible streaming services | Spotify Deezer Qobuz Amazon Music Tidal Apple Music BBC Sound |
Compatible network protocols | Spotify Connect Tidal Connect Apple AirPlay Google Cast |
Supported sampling rates | PCM up to 32bit 384kHz |
Amplification power | 2x75W @ 4Ω |
Amplification type | Class D |
Tuner | FM / DAB / DAB+ |
Supply voltage | 100-240VAC 50/60Hz |
Dimensions | 300 x 275 x 95mm |
Weight | 4.2kg |
Finish | Composite walnut |
Package | 1x Ruark Audio R610 1x RotoDial remote control 1x Radio antenna 1x USB-C to USB-C cable 1x Pair of speaker cables 1x Power cord |
Input | Optical |
Input | Phono |
Input | RCA |
Input | RJ45 |
Input | HDMI ARC |
Input | USB |
Output | RCA |
Output | Subwoofer |
Output | Speaker terminal |
DAC / ADC Chip | Burr Brown |
Max sampling rate | 384kHz |
Color | Wood |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 75.0 |
Remote Control | Yes |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Chromecast |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | Spotify Connect |
