SMSL A100 Amplifier Class D Infineon MA12070 Bluetooth 5.0 2x80W 4 Ohm
SMSL offers with the A100 a compact and affordable but nevertheless powerful Class D amplifier, based on an Infineon MA12070 chip allowing it to develop 2x80W under 4Ω. Simple and efficient, the A100 is simple to use and practical. It integrates what's more a Bluetooth 5.0 reception allowing to broadcast its music remotely, directly from a smartphone or a tablet.
Reference : 15915
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 10-07-2025.
SMSL A100
SMSL A100 Amplificateur Class D Infineon MA12070 Bluetooth 5.0 Subwoofer 2x80W 4 Ohm
Infineon MA12070 Amplifier
The Class D amplification stage of the A100 is based on an Infineon MA12070 chip, offering a good energy reserve while ensuring a clear and faithful reproduction. This one takes advantage of the MERUS architecture, in which each half-bridge uses four MOSFETS.
Bluetooth 5.0
In addition to its stereo RCA and USB-A input, the A100 embeds a Bluetooth 5.0 receiver allowing you to broadcast your music from a distance, from a connected smartphone for example. The integrated chip supports the aptX transmission codec ensuring very good audio quality and signal stability.
Subwoofer output
In addition to the classic speaker output, the A100 is equipped with a subwoofer output on stereo RCA. It is thus possible to connect an active subwoofer and thus the integration of a 2.1 system.
1Volume button
2Mute button
3Input selection
4Right speaker output
5RCA Input
6Left speaker output
7Power button
8Power connector
9USB-A Input
10Active subwoofer output
Product typeAmplifier
Amplifier typeClass D
InputsBluetooth
1x USB-A
1x Stereo RCA
OutputsSpeaker terminals
1x Stereo RCA subwoofer output
THD+N0.005%
SNR103dB
Channel separation88dB
Output power2x80W @ 4Ω
2x40W @ 8Ω
Input sensitivity180mW
Input impedance22kΩ
Supply voltage100-240VAC
Consumption35W
Dimensions165 x 150 x 43mm
Weight600g
ColorGray
PackageSMSL A100
1x Power cable
OutputSubwoofer
OutputSpeaker terminal
ColorGray
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)80.0
Remote ControlYes
2 reviews
Recommandé !
Commandé pour un usage périphérique, mon A100 a intégré pour quelques jours l’ensemble vintage de mon système principal. Le résultat est une révélation sur le niveau de qualité des amplificateurs Classe D actuels. Le premier enseignement est que ce petit appareil qui reste tiède à l’usage produit une énergie totalement suffisante pour soutenir des enceintes 2-voix 6 Ohms / 86 dB dans une absence totale de souffle. Ramené au potentiomètre en façade, une source moderne laisse le volume au premier quart de la course; un enregistrement pré ”loudness” war pousse à la moitié du chemin. Le deuxième enseignement est qu’il n’y a strictement rien que ce petit appareil sans prétention ne fait pas mieux que mon amplificateur classe AB vintage (36 ans d’âge) - avec un 1/6ème de l’encombrement. Dans le cadre d’un usage où le niveau sonore ne dépasse pas les 95 dB et rarement les 10 premiers watts en crête d’un amplificateur, il est tout bon. La transparence du rendu du A100 est même une invitation à utiliser son matériel numérique moins récent. Ainsi la rondeur suave de mon DAC vieux de 7 ans est sublimée alors que l’hyper pointillisme et les attaques tranchantes d’un DAC de 2022 paraissent du coup sur-joués.
Par contre, il ne faut pas s’attendre à un miracle avec l’entrée USB. Le volume sonore est nettement plus faible, son rendu est sourd et étroit. Testée avec un mini ordinateur ARM, Spotifyd 0.3.3 plante lors des interactions, MPD et MOC par contre fonctionnent parfaitement, Avec Windows aucun problème. Côté Bluetooth, pas de problème de compatibilité avec un mobile Apple ou Android.
Dans sa fonction première, ce produit est très satisfaisant. Sa sortie subwoofer promet qu’il saura se rendre utile sur le long terme. Je le recommande vivement.
This review has been posted for SMSL A100 Amplifier Class D Infineon MA12070 Bluetooth 5.0 2x80W 4 Ohm
Wow...!
Nicely made and finished, feels and looks solid. 40w per channel drives my Wharfedale 12.1 speakers very well, plenty loud enough...! In combination with the smsl su6 dac, a great system, just add a source.
 (3)
SMSL offers with the A100 a compact and affordable but nevertheless powerful Class D amplifier, based on an Infineon MA12070 chip allowing it to...
