de la puissance, du volume, mais quid de la definition et de la musique ?
pas de la hifi...
This product has been replaced by the new version, the SMSL AO200 Class D Amplifier MA5332MS.
Class D Amplifier 2x MA12070 Balanced Bluetooth 5.0 Subwoofer
The SMSL AO200 is a compact and powerful Class D digital amplifier, capable of developing a power of 2x90W under 4Ω thanks to its two Infineon MA12070 amplifier chips. A power totally mastered in order to reveal a sound restitution of a great purity and dynamics. Versatile, it benefits from both a balanced input, but also Bluetooth 5.0 reception and a Subwoofer output.
In order to integrate with all audio systems and to adapt to all needs, the SMSL AO200 is equipped with two inputs. There is an unbalanced input on RCA and a balanced input on XLR. Each connector is gold plated to ensure a very good conductivity and durability.
With the AO200 it is possible to set up a 2.1 audio system, thanks to an output on RCA connector. Ideal to reach deep and punchy bass.
At the heart of the AO200's amplifier stage are two Infineon MA12070 Class D amplifier chips. These allow to offer a consequent power, associated with a high efficiency of 92%, a reduced consumption and then of course a sound of a great richness. These chips adopt the new MERUS architecture, totally different from a classic Class D architecture. Each half-bridge uses four MOSFETS (M1-M4) and a capacitor between them as an additional power rail to generate a three-level output signal at the output node.
With its Bluetooth 5.0 receiver, the AO200 allows you to broadcast your music from a distance, directly from a smartphone for example. The 5.0 standard ensures a fast and stable transmission over a distance of 10m.
The AO200 has 8 preset equalizers to suit your listening and your audio system. You can also manually adjust the bass and treble levels for fine tuning.
The AO200's circuitry uses high quality components to provide the best possible performance. We can find a particularly precise and low distortion NJW1194 volume controller, EOP1678 AOPs, ERO capacitors or low noise MELF resistors.
The power supply stage is not to be outdone since it is based on a power supply module custom designed to provide an instantaneous power of 300W. It thus allows to favour a beautiful dynamic while limiting efficiently the impact of the interferences. For that it uses in particular a large transformer with low leakage and a filtering of the input at two levels.
1 | Multifunction knob |
2 | IR Receiver |
3 | Screen |
4 | Single-ended RCA input |
5 | Bluetooth antenna concector |
6 | Right channel output |
7 | Power supply connector |
8 | Balanced XLR input |
9 | Subwoofer output |
10 | USB-A input |
11 | Left channel output |
12 | Power button |
Product type | Class D Amplifier |
Inputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA Bluetooth 5.0 1x USB-A |
Outputs | Speaker terminals 1x Subwoofer (RCA) |
THD+N | 0.003% |
SNR | 110dB |
Channel separation | 98dB |
Input sensitivity | 280mV |
Input impedance | 47kΩ |
Output power | 2x 150W @ 2Ω 2x 90W @ 4Ω 2x 50W @ 8Ω |
Supply voltage | 110-240VAC |
Consumption | Normal volume level: 40W Standby: 0.5W |
Dimensions | 187.5 x 154 x 40mm |
Weight | 960g |
Color | Black |
Input | USB |
Input | XLR |
Input | RCA |
Input | Bluetooth |
Output | Speaker terminal |
Output | Subwoofer |
Color | Black |
Channel | 2.1 |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Infineon MA12070 |
Power (W) | 90.0 |
Average votes 4.5 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Louis M.
Bernard T.
Pascal R.
Damien C.
