TONEWINNER AD-60 Amplifier
The Tonewinner AD-60 is an integrated power amplifier offering 2 x 80W power at 4Ω while maintaining very low distortion and response time thanks to its Class AB design. Furthermore, its wide range of connectors means it can easily be used in a wide range of configurations, from home cinema with its HDMI/ARC socket to remote use via a simple Bluetooth 5.0 connection.
By buying this product you get 44 loyalty points
Reference : 19416
449,00 €tax incl.
374,17 € tax excl.
Last items in stock !
Shipping date: 30-09-2025.
TONEWINNER AD-60 Class AB Stereo Amplifier Bluetooth 2x80W 4 Ohm Silver
TONEWINNER AD-60 : Front view
The Tonewinner AD-60 is an integrated power amplifier offering 2x80W power at 4Ω while maintaining very low distortion and response time thanks to its Class AB design. Furthermore, its wide range of connectors means it can easily be used in a wide range of configurations, from home cinema with its HDMI/ARC socket to remote use via a simple Bluetooth 5.0 connection.
Tonewinner AD-60 : An ultra-large toroidal transformer
The Tonewinner AD-60 is powered by a toroidal transformer capable of delivering up to 100W, combined with high-performance capacitors to produce a clean, constant electrical signal, perfect for Hi-Fi use.
Tonewinner AD-60 : 80W output power at 4Ω
In terms of its amplification stage, the Tonewinner AD-60 can deliver 2 x 80W at 4 Ω and 2 x 50W at 8 Ω while producing a remarkably transparent sound. Its volume control combined with coupling and filtering capacitors ensures minimal alteration of the signal, with an output total harmonic distortion of just 0.025% and an impressive frequency response from 20Hz to 100kHz.
Tonewinner AD-60 : A wide range of connectivity options
The AD-60 amplifier has been designed above all with flexibility of use in mind. It has an analogue RCA input and a plethora of digital inputs: TF card, USB-C for connection to a PC, USB-A, Toslink optical, coaxial and HDMI / ARC. Furthermore, the AD-60 offers a Bluetooth 5.0 connection and has an Android and IOS compatible application.
TONEWINNER AD-60 : connectors
Product typeIntegrated amplifier
Amplification typeClass AB
Number of channelsStereo (2)
Inputs1x USB-A
1x USB-C
1x Slot carte TF
1x HDMI ARC
1x Optical Toslink
1x Coaxial
1x Stereo RCA
1x Bluetooth 5.0
Outputs1x Stereo speaker terminal
1x 3.5mm Jack headphone output
1x Subwoofer output
Output power80W @ 4Ω
50W @ 8Ω
Total harmonic distortion (THD)≤ 0.025% @1kHz
Input impedance20kΩ
Signal-to-noise ratio (SNR)100dB
Frequency response20Hz - 100kHz (+1/-3dB)
Gain23.9dB
Supported Bluetooth CodecsSBC
AAC
Supply voltage115V/60Hz
230V/50Hz
Dimensions300 x 335 x 83mm
Net weight5.5kg
ColorSilver
Package1x Tonewinner AD-60
1x Remote control (CR2016 battery not included)
1x Pwer cable
1x Optical fibre cable
InputHDMI ARC
InputSD Card
OutputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
ColorSilver
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)80.0
Remote ControlYes
The Tonewinner AD-60 is an integrated power amplifier offering 2 x 80W power at 4Ω while maintaining very low distortion and response...
