The Tonewinner AD-60 is an integrated power amplifier offering 2x80W power at 4Ω while maintaining very low distortion and response time thanks to its Class AB design. Furthermore, its wide range of connectors means it can easily be used in a wide range of configurations, from home cinema with its HDMI/ARC socket to remote use via a simple Bluetooth 5.0 connection.
The Tonewinner AD-60 is powered by a toroidal transformer capable of delivering up to 100W, combined with high-performance capacitors to produce a clean, constant electrical signal, perfect for Hi-Fi use.
In terms of its amplification stage, the Tonewinner AD-60 can deliver 2 x 80W at 4 Ω and 2 x 50W at 8 Ω while producing a remarkably transparent sound. Its volume control combined with coupling and filtering capacitors ensures minimal alteration of the signal, with an output total harmonic distortion of just 0.025% and an impressive frequency response from 20Hz to 100kHz.
The AD-60 amplifier has been designed above all with flexibility of use in mind. It has an analogue RCA input and a plethora of digital inputs: TF card, USB-C for connection to a PC, USB-A, Toslink optical, coaxial and HDMI / ARC. Furthermore, the AD-60 offers a Bluetooth 5.0 connection and has an Android and IOS compatible application.
Product type | Integrated amplifier |
Amplification type | Class AB |
Number of channels | Stereo (2) |
Inputs | 1x USB-A 1x USB-C 1x Slot carte TF 1x HDMI ARC 1x Optical Toslink 1x Coaxial 1x Stereo RCA 1x Bluetooth 5.0 |
Outputs | 1x Stereo speaker terminal 1x 3.5mm Jack headphone output 1x Subwoofer output |
Output power | 80W @ 4Ω 50W @ 8Ω |
Total harmonic distortion (THD) | ≤ 0.025% @1kHz |
Input impedance | 20kΩ |
Signal-to-noise ratio (SNR) | 100dB |
Frequency response | 20Hz - 100kHz (+1/-3dB) |
Gain | 23.9dB |
Supported Bluetooth Codecs | SBC AAC |
Supply voltage | 115V/60Hz 230V/50Hz |
Dimensions | 300 x 335 x 83mm |
Net weight | 5.5kg |
Color | Silver |
Package | 1x Tonewinner AD-60 1x Remote control (CR2016 battery not included) 1x Pwer cable 1x Optical fibre cable |
Input | RCA |
Input | Optical |
Input | SD Card |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Input | HDMI ARC |
Output | Jack 3.5mm |
Output | Speaker terminal |
Output | Subwoofer |
Color | Silver |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 80.0 |
Remote Control | Yes |
