YAMAHA MUSICCAST R-N402D Amplifier Streamer WiFi AirPlay DLNA Bluetooth 2x115W 4 Ohm 24bit 192kHz DSD128
The Yamaha R-N402D is a second-generation MusicCast-compatible HiFi amplifier with DAB tuner that offers great sound quality and rich, musical reproduction. It's versatile and supports a variety of sources and streaming services. It also allows you to play your audio files directly from your smartphone, PC or NAS.
By buying this product you get 54 loyalty points
Reference : 15758
549,00 €tax incl.
457,50 € tax excl.
Yamaha MusicCast N-402D
YAMAHA MUSICCAST R-N402D Amplificateur Lecteur Réseau WiFi AirPlay DLNA Bluetooth 2x115W 4 Ohm 24bit 192kHz DSD128
Suitable for all your sources
The Yamaha R-N402D is both an amplifier and a network player that can access your audio files stored on your local network from a computer or NAS. It is also capable of streaming your music from many popular streaming services and web radio (via vTuner). In addition, the MusicCast app allows you to enjoy music stored on your smartphone or tablet directly via a wireless connection.
MusicCast
The MusicCast system uses a high-performance wireless network to stream your music unaltered. Using this protocol, you can stream your audio files directly from a smartphone, PC or NAS to your MusicCast devices. In addition, audio content from smartphones and tablets can be distributed to multiple MusicCast devices in multiple rooms.
Bluetooth, AirPlay & DLNA
With the R-N402D, your smartphone becomes a true audio source, thanks to the device's compatibility with Bluetooth, AirPlay and DLNA transmission protocols. It's easy to stream your music from your audio applications, radios or streaming services.
Use the R-N402D as a Bluetooth source
The R-N402D is equipped with the latest Bluetooth technology, making wireless use easier than ever. For example, you can stream your music from the R-N402D to a Bluetooth headphone for a private listening session, to a Bluetooth speaker or to any other compatible device.
DAB and DAB+ radios
The network player supports DAB and DAB+ technologies, digital audio broadcasting systems offering access to a wide range of radio stations with high quality sound reproduction. It also automatically finds available stations in a list and displays information such as the station name. No less than 40 DAB/DAB+ stations can be stored on the R-N402D.
Easily access your USB storage devices
The front panel of the R-N402D provides a USB-A port for connecting a USB storage device. This allows you to quickly access all your downloaded music, with the digital connection ensuring high quality playback.
Compatibility with gapless playback
Many live and classical music albums should not have any breaks between songs. Gapless mode ensures that there are no pauses between audio files, so you can play these albums the way they were intended.
High resolution & 24bit DAC
Thanks to its Burr Brown 24bit DSD1791 DAC chip, the R-N402D is able to read high resolution audio streams. It is thus possible to enjoy WAV or FLAC files up to 24bit 192kHe and Apple Lossless up to 24bit 96kHz. The device also supports DSD streams up to DSD128 for an incredibly accurate reproduction.
Digital audio input for TV and Blu-ray player
The R-N402D has both optical and coaxial digital audio inputs. The former is designed to receive the signal from a TV and the latter from a Blu-ray player. The sound is thus managed in a completely digital way, offering a dynamic and crystal clear reproduction, whatever your sources.
A simple and sophisticated design
The R-N402D inherits the simple yet elegant styling that Yamaha has become known for. The front panel buttons are also ergonomically designed. The brushed aluminum front panel and rotary knobs are inspired by the luxurious designs of Yamaha's high-end models.
Product typeAmplifier
Streamer
ConnectivityWiFi
DLNA 1.5
AirPlay
Bluetooth (SBC, AAC)
DAB/DAB+
InputsWiFi
Bluetooth
1x Ethernet RJ45
1x USB-A (USB Host)
1x Optical Toslink
1x Coaxial
4x Stereo RCA
Outputs2x Stereo speaker terminals
1x Steroe RCA
Bluetooth
1x Stereo Jack 6.35mm headphone output
Supported file formatsMP3, WMA, MPEG4, AAC, WAV, FLAC, AIFF, ALAC, DSD
Supported sampling ratesPCM up to 24bit 192kHz
DSD up to DSD128
Supported streaming servicesSpotify
Spotify Connect
Qobuz
Deezer
Tidal
Airable (TuneIn)
Napster
Pandora
SiriusXM
Max output power2x 115W @ 4Ω, 1kHz, 0.7% THD
2x 140W @ 8Ω, 1kHz, 10% THD
Dynamic power / channel125W @ 8Ω
150W @ 6Ω
165W @ 4Ω
180W @ 2Ω
SNRCD : 100dB
FM Mono : 71dB
FM Stereo : 70dB
Consumption1.9W
Dimensions435 x 141 x 340mm
Weight7.3kg
InputWiFi
InputRJ45
OutputJack 6.35mm
OutputSpeaker terminal
OutputBluetooth
ColorGreen
ClassN/A
Amplifier chipN/A
The Yamaha R-N402D is a second-generation MusicCast-compatible HiFi amplifier with DAB tuner that offers great sound quality and rich, musical...
