MOGAMI 2319 High impedance Patch Cable 0.305mm² Ø5mm
4.0 / 5
Reference : 11403
1,79 €tax incl.
1,49 € tax excl.
Shipping date: 27-05-2025.
Mogami 2319 cable is a high impedance transmission cable, perfectly suited for music applications and instruments. As for example electric guitars which consist of high-impedance circuits driven by the voltage.
Ce cable has been designed to have very low microphone effects thanks to its layer of conductive PVC placed under the shielding conductor. This property is very sought after especially for equipping musical instruments.
The isolation conductors is made of PE (Polyethylene), known for its excellent electrical characteristics, as well as a black PVC outer sheath bringing the cable up to 5mm in total diameter.
Herconstruction is robust and flexible, allowing easy cable handling regardless of application and requirements.
You will find in the documents enclosed below a PDF detailing the technical characteristics of the cable.
Main Features :
  • 0.305mm² conductor (# 23AWG)
  • PE conductor insulation (Polyethylene): Ø 1.6mm
  • Upper insulation: Conductive PVC Ø 1.8mm
  • Black PVC sleeve
  • Overall outer diameter: Ø 5mm
  • Flexible and robust construction
  • Sold by the meter
FEATURESELECTRIC & MECHANICAL ERRORS
Part No.W2319
DC Resistance at 20 ° C </ Td>Inner Conductor0.064Ω / m (0.020W / Ft) </ Td>
Shield Conductor0.026Ω / m (0.0079Ω / Ft)Capacitance at 1kHz, 20 ° C </ Td>155pF / m (47.3pF / Ft)Inductance0.3μH / m (0.092μH / Ft)Electrostatic Noize *0.13mV Max.Electromagnetic Noise At 10kHz *0.07mV Max.microphonics *0.3mV MaxVoltage BreakdownMust withstand at DC 500V / 15sec.Insulation Resistance100000 MΩ × m Min. at DC 500V, 20 ° CFlex Life11,000 cycles</ Td>Tensile Strength (26 ° C, 65% RH) </ Td>303 NEmigrationNon-emigrant to ABS resinApplicable Temperature-20 ° C~ + 60 ° C (-4 ° F. + 140 ° F)
MOGAMI W2319 Câble
Diameter (mm)5.0
Length (m)Sold by length
Number of conductors1
Insulation materialPE
Insulation materialPVC
ShieldingNo
Section (mm²)0.305
Ground / ShieldingYes
2 reviews
MOGAMI W2319 Câble Patch à haute impédance 0.305mm² Ø5mm
Super !!!
Il m'aide en interne basse et guitare...Je suis ingénieur du son (Zingaro,) j'ai 45 ans. J'ai fait une cage de Faraday ( en peinture graphite, 5 couches. je n'utilise pas le spray mais la peinture)... Je suis à ma 10e gratte & basse.
J'ai l'opportunité de la faire en cuivre, on verra si ça marche
À bientôt
This review has been posted for MOGAMI 2319 High impedance Patch Cable 0.305mm² Ø5mm
Bien ... mais ...
Le métal du câble semble très correct malgré la fine section de ce dernier. Le guitariste à qui est destiné ce câble s'est plaint d'une "perte de puissance et de la disto" durant un concert : défauts apparemment non constatés par le public ... Donc 3 étoiles dans le doute .
