AMANERO COMBO384SE Digital interface USB 384kHz / SPDIF WM8804 to I2S / DSD
Combo384SE version also incorporating a bidirectional S / PDIF WM8804 interface which can function as input or as output according to the needs of your project.
Reference : 14535
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 07-04-2026.
Amanero COMBO384SE
VA variant of the excellent USB to I2S Amanero interface, this version Combo384SE also incorporates a bidirectional S/PDIF WM8804 interface that can function as input or output according to the needs of your project.
Associated with a DAC with I2S input, this module makes it possible to create a complete audio device capable of reading audio streams from a digital source (PC Mac or Linux) with a 75 ohm SPDIF connector for additional input / output.
The SPDIF / USB and I2S circuits are isolated by capacitors to avoid any leakage and interference between each digital stage.
USB & S/PDIF to I2S
In its RX configuration, the S / PDIF interface functions as a digital input. The Amanero Combo384SE module offer a high-quality i2S output from a USB source (Windows / Mac / Linux machine) as well as a 75 ohm S/PDIF source (TV, CD player, game console. ..etc.).
The USB input allows support for DSD signals up to DSD512 and PCM streams up to 384Khz.
Note that the output of the SPDIF interface is not connected to the USB connector. It is therefore not possible to use this module to send SPDIF stream to USB.
USB to I2S & S/PDIF
In its TX configuration, the S / PDIF interface functions as a digital output. The Amanero Combo384SE module allows you to take advantage of an i2S output and an S/PDIF output from a USB source (Windows / Mac / Linux machine).
Please note, in this configuration the S/PDIF output is configured to mute automatically when the sampling rate of the digital stream exceeds S/PDIF standard.(192kHz). The same goes for DSD streams.
TypeDigital Interface
InputsUSB-B
S/PDIF (input or output)
OutputsI2S
Sampling rate44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz (USB)
44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz (SPDIF)
Output formatI2S 32bit ou DSD64,DSD128
Windows DSD256,DSD512 Native
Clocks2x TCXO low phase noise
OSNo driver needed for Mac Os 10.6 + or Linux (Kernel compatible UAC)
On Windows : compatibility drivers : KS / Wasapi / WDM/ASIO
InputS/PDIF
OutputI2S
OutputSPDIF
Max sampling rateDSD512
Max sampling rate384kHz
Interface chipWM8804
3 reviews
Works fine
It works fine and is easy to install. Delivery was fast and my DIY DAC is now capable to get USB input. Perfect.
This review has been posted for AMANERO COMBO384SE Digital interface USB 384kHz / SPDIF WM8804 to I2S / DSD
Excellent customer support
my request was resolved very quickly
excellent customer support
customer service is fast and excellent
Combo384SE version also incorporating a bidirectional S / PDIF WM8804 interface which can function as input or as output according to the needs of...
