I2S / USB to AES/EBU / Coaxial / Optical / HDMI Digital Interface 32bit 384kHz DSD128
This module will allow you to combine an Amanero or XMOS USB interface (sold separately) to enjoy a complete and versatile digital interface. You will therefore have an I2S or USB input (input selection via a jumper) as well as a complete panel of outputs with HDMI, Coaxial S/PDIF, Toslink Optics and AES/EBU. The interface supports sampling rates up to 32bit 384kHz and DSD128 via the HDMI output. The Coaxial and XLR outputs are galvanically isolated to significantly reduce noise.
The USB Amanero / XMOS interface is sold separately.
Note: Does not support I2S modules without Master Clock (MCLK) such as the Raspberry Pi. Supports the conversion of I2S signals via modules with MCLK, BCLK, LRCK, DATA.
Note: For 32bit 384kHz or DSD64/128 files to be supported via HDMI, it is necessary to use a low level input.
This module must be supplied with 5V via its J5 connector.
Product type | Digital interface |
Chip | WM8805 |
Inputs | USB (USB Interface sold separately) OR I2S |
Outputs | 1x HDMI 1x Optical Toslink 1x Coaxial S/PDIF 1x AES/EBU |
Compatible USB interface | Amanero XMOS |
I2S / HDMI Compatibility | Audio-GD / PS Audio |
Supported sampling rate | Coaxial, AES/EBU : up to 24bit 192kHz Optical : up to 24bit 48kHz HDMI : up to 32bit 384kHz / DSD128 |
Power supply | 5V DV via J5 connector |
Dimensions | 100 x 73.5 x 26.5mm |
Fixation holes spacing | 90 x 64mm |
Input | I2S |
Output | XLR |
Output | HDMI |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Max sampling rate | DSD128 |
Max sampling rate | 384kHz |
Interface chip | WM8805 |
