LHY AUDIO Digital Interface Module I2S Bluetooth 5.1 USB to SPDIF AES/EBU I2S HDMI 32bit 384kHz DSD256
This LHY Audio digital interface module features I2S (on solder pads) and Bluetooth 5.1 inputs for wireless audio streaming from a smartphone or tablet. It also allows the integration of a USB Amanero or XMOS interface module (sold separately). The output is made in coaxial SPDIF and optical Toslink thanks to an Cirrus Logic WM8805 interface chip or in AES / EBU.
Reference : 17436
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 17-07-2025.
LHY Audio Digital interface module
LHY Audio Module d'interface numérique I2S Bluetooth 5.1 USB vers SPDIF AES/EBU I2S HDMI 32bit 384kHz DSD256
The Bluetooth input uses a Qualcomm QCC5125 receiver, supporting the high-resolution codecs aptX, aptX LL, aptX HD and LDAC for wireless quality sound reproduction. In addition, the module supports high-resolution audio streams via I2S or USB, up to PCM 32bit 384kHz and DSD256.
1I2S via HDMI output
2Optical Toslink output
3Coaxial output
4AES/EBU output
5USB interface connector
6USB/Bluetooth switch
75V power input
8I2S input
9Bluetooth 5.1 receiver
Product typeDigital interface board
InputsBluetooth 5.1
1* I2S (solder pads)
1* USB (via USB interface sold separately)
Outputs1* Coaxial
1* AES
1* Optical Toslink
1* I2S via HDMI
Bluetooth chipQualcomm QCC5125
Supported Bluetooth codecSBC, AAC, aptX, aptX LL, aptX HD, LDAC
SPDIF interfaceCirrus Logic WM8805
Supported sampling ratesI2S (HDMI) : PCM up to 32bit 384kHz, DSD up to DSD256
Optical / Coaxial / AES : PCM up to 24bit 192kHz
Supply voltage5VDC (power supply sold separately)
Dimensions99*74mm
Package1* LHY Audio Module interface
1* Bluetooth antenna
Screws
InputI2S
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
OutputAES/EBU
Max sampling rate384kHz
Max sampling rateDSD256
Interface chipWM8805
This LHY Audio digital interface module features I2S (on solder pads) and Bluetooth 5.1 inputs for wireless audio streaming from a smartphone or...
