This LHY Audio digital interface module features I2S (on solder pads) and Bluetooth 5.1 inputs for wireless audio streaming from a smartphone or tablet. It also allows the integration of a USB Amanero or XMOS interface module (sold separately). The output is made in coaxial SPDIF and optical Toslink thanks to an Cirrus Logic WM8805 interface chip or in AES / EBU.
The Bluetooth input uses a Qualcomm QCC5125 receiver, supporting the high-resolution codecs aptX, aptX LL, aptX HD and LDAC for wireless quality sound reproduction. In addition, the module supports high-resolution audio streams via I2S or USB, up to PCM 32bit 384kHz and DSD256.
1 | I2S via HDMI output |
2 | Optical Toslink output |
3 | Coaxial output |
4 | AES/EBU output |
5 | USB interface connector |
6 | USB/Bluetooth switch |
7 | 5V power input |
8 | I2S input |
9 | Bluetooth 5.1 receiver |
Product type | Digital interface board |
Inputs | Bluetooth 5.1 1* I2S (solder pads) 1* USB (via USB interface sold separately) |
Outputs | 1* Coaxial 1* AES 1* Optical Toslink 1* I2S via HDMI |
Bluetooth chip | Qualcomm QCC5125 |
Supported Bluetooth codec | SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
SPDIF interface | Cirrus Logic WM8805 |
Supported sampling rates | I2S (HDMI) : PCM up to 32bit 384kHz, DSD up to DSD256 Optical / Coaxial / AES : PCM up to 24bit 192kHz |
Supply voltage | 5VDC (power supply sold separately) |
Dimensions | 99*74mm |
Package | 1* LHY Audio Module interface 1* Bluetooth antenna Screws |
Input | I2S |
Input | USB |
Input | Bluetooth |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | I2S LVDS via HDMI |
Output | AES/EBU |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Interface chip | WM8805 |
