This Plug & Play USB 2.0 isolator module lets you enjoy a cleaner signal on a wide range of devices thanks to its four USB-A outputs. It incorporates an ADuM3160 digital isolator, a USB hub chip and can be powered from either the USB-B input or an external 5V DC power supply (sold separately). Each USB port on this module has a dedicated ESD protection chip. This USB isolator supports data transfers from 1.5Mbps to 12Mbps.
The output power of the B0505S is 1x2W. When the total operating current of the USB device exceeds 400mA, the DC5V external power supply is required.
1 | USB-A input |
2 | USB ADuM3160 isolator |
3 | USB Hub |
4 | ESD protections |
5 | B0505S |
6 | 5V DC external power supply interface |
7 | 4x USB indicators |
8 | 4x USB-A output |
Product type | USB isolator module ADUM3160 |
Input | 1x USB-B |
Ouputs | 4x USB-A |
USB compatibility | 2.0 |
Bandwidth | 1.5Mbps to 12Mbps |
ADuM3160 chip isolation voltage | 2500V |
Power supply module isolation voltage | 1500V |
Power supply voltage | 5V DC |
Dimensions | 70*38mm |
Weight | 30g |
