USB to I2S Interface Board XMOS XU208 Bluetooth 5.0 aptX-HD 32bit 384kHz DSD256
This digital interface module integrates a USB-B input and an I2S output. A powerful XMOS XU208 chip is used to decode the audio stream. It allows the support of high sampling rates, up to PCM 32bit 384kHz and DSD256. In addition, it also integrates a Bluetooth 5.0 receiver, thanks to a CSR8675 chip for remote broadcasting from a smartphone or tablet.
Reference : 15976
89,00 €tax incl.
74,17 € tax excl.
USB to I2S interface
Interface USB vers I2S XU208 Bluetooth 5.0 aptX-HD 32bit 384kHz DSD256
This digital interface module integrates a USB-B input and an I2S output. A powerful XMOS XU208 chip is used to decode the audio stream. It allows the support of high sampling rates, up to PCM 32bit 384kHz and DSD256. In addition, it also integrates a Bluetooth 5.0 receiver, thanks to a CSR8675 chip for remote broadcasting from a smartphone or tablet. It supports the high quality codecs aptX and aptX-HD ensuring a great sound quality in wireless. An antenna ensures a stable signal transmission.
Product typeUSB to I2S interface
Inputs1x USB-B
Bluetooth 5.0
Output1x I2S
Native DSD up to DSD256
DSD up to DSD256
OS CompatibilityWindows 7 / 8 / 10
Mac OS 10.6 or later
Linux
Android 4.2 or later
Supported Bluetooth codecsaptX
aptX-HD
Dimensions78.4 x 32 x 14.8mm
Mounting holes spacing63.7 x 25mm
OutputI2S
Max sampling rate384kHz
Max sampling rateDSD256
Interface chipXMOS XU208
This digital interface module integrates a USB-B input and an I2S output. A powerful XMOS XU208 chip is used to decode the audio stream. It allows...
