JANTZEN AUDIO STANDARD Z-CAP Capacitor 400V 4.7μF
Reference : 14922
4,70 €tax incl.
3,92 € tax excl.
Shipping date: 02-09-2025.
Jantzen Audio Standard Z-Cap
Capacité MKP non-polar 4,70μF
The Jantzen Audio Standard-Z Cap series offers affordable audio capacitors for your high fidelity hardware build / repair / upgrade projects. They stand out thanks to their excellent value for money in high audio performance. These capacitors offer a high and fast reaction, detailed sound and a smooth signal compared to what the competition offers in the single polypropylene foil capacitor market.
The dielectric fluid used is nitrogen, which allows denser foil when assembling the capacitor while avoiding the risk of evaporation.
This Jantzen Audio Standard Z Cap capacitor model has a capacitance of 4,70μF for a diameter of Ø 20mm and a length of 31mm.
TypeNon-polarized MKP (single foil lane)
DielectricPolypropylene film
Construction: Round tubular type axial leads
Rated Voltage400 VDC / 250 VAC
ElectrodesAluminum metallized vacuum deposited
ContactsNon-inductive zinc thermally sprayed extended film
CoatingBlue plastic tape wrapped and sealed in black resin
LeadsTin plated oxygen free copper
Tolerance+/- 5%
Dielectric absorption factor=0.5% @20°C
Dielectric thicknessPB=5µm
Self-inductance=15 nH
Insulation resistance=100.000 MOhm@20°C
Temperature coefficient-200°Cx10-6/°C
Temperature Range-55°C à +85°C
Metal layer thicknessPB =1.2 Ohm/cm2
Capacitance4,70μF
DiameterØ 20mm
Length31mm
Tolerance (%)5
Capacitor capacitance (µF)4.7
Rated voltage (V)400.0
Capacitor typeFilm capacitor
Capacitor formatAxial
3 reviews
Bon rapport qualité prix.
Le Jantzen bleu me sert de base pour mes filtres dans le médium aigu depuis longtemps.
C'est une assurance d'un son équilibré avec des timbres naturels.
On peut bypasser l'aigu avec un petit condensateur de qualité supérieure pour peaufiner.
De part sa taille compacte il remplace avantageusement les condos parfois agressifs d'origine dans les enceintes du commerce.
Il y a un temps de stabilisation de quelques jours afin que le son soit vraiment agréable .
This review has been posted for JANTZEN AUDIO STANDARD Z-CAP Capacitor 400V 4.7μF
Celestion SL6
Merci à Auphonics pour leur rapidité à traiter les commandes.
J'ai choisi les condensateurs ANTZEN AUDIO STANDARD Z-CAP pour mettre à jour mes enceintes Celestion SL6. Ils s'intègrent parfaitement dans le filtre, et le résultat est à la hauteur de mes attentes. Je retrouve pleinement la signature sonore caractéristique des SL6.
Jantzen Z-Caps
Very detailed and fantastic value, clear distinct audio
