DAYTON AUDIO DCS385-4 Speaker Driver Subwoofer 300W 4 Ohm 92dB 19Hz - 200Hz Ø38.1cm
The DCS385-4 is a standard subwoofer that will fit most systems, whether replacing a HS subwoofer of the same size or simply creating a new subwoofer. For maximum versatility, this speaker has been designed to be suitable for both bass reflex and closed cabinet applications.
Reference : 15229
169,00 €tax incl.
140,83 € tax excl.
Last items in stock !
Shipping date: 16-05-2025.
dayton audio dsc385-4 subwoofer
The DCS385-4 is a standard subwoofer that will fit most systems, whether replacing a HS subwoofer of the same size or simply creating a new subwoofer. For maximum versatility, this speaker has been designed to be suitable for both bass reflex and closed cabinet applications. The very robust diaphragm and the wide suspension ensure a high linear excursion for excellent low frequency performance.
Speaker typeSubwoofer
Nominal diameter38.1cm (15")
Diaphragm materialPaper / Kevlar
Magnet materialFerrite
Voice coil wire materialCopper
Overall outside diameter387mm
Depth185.4mm
Power handlingRMS : 300W
MAX : 600W
Impedance
Sensitivity91.7dB @ 2.83V/1m
Frequency response19Hz - 200Hz
DC Resistance (Re)3.3Ω
Voice coil inductance (Le)2.2mH
Mechanical Q (Qms)5.27
Electromagnetic Q (Qes)0.42
Total Q (Qts)0.39
Moving mass of diaphragm (Mmd)273g
Mechanical compliance of suspension (Cms)0.3mm/N
Surface area of cone (Sd)850.1cm²
Maximum linear excursion (Xmax)9.3mm
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume108.45L
Sealed F339Hz
Vented Volume347.16L
Vented F322Hz
Speaker Power (W RMS)250.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)381.0
Diaphragm typePaper
Diaphragm typeKevlar
Efficiency / Sensitivity (dB)92.0
Max Linear Excursion (Xmax) (mm)9.3
Lowest frequency (Hz)19
Highest frequency (Hz)200
Highest frequency (Hz)500
The DCS385-4 is a standard subwoofer that will fit most systems, whether replacing a HS subwoofer of the same size or simply creating a new...
