DAYTON AUDIO RSS315HO-44 HO DVC Speaker Driver Subwoofer Aluminium 700W 4+4 Ohm 85dB 20Hz - 500Hz Ø30.5cm
Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with the entire Reference Series, these subwoofers feature ultra-low distortion.
By buying this product you get 31 loyalty points
Reference : 14688
319,00 €tax incl.
265,83 € tax excl.
Last items in stock !
Shipping date: 13-05-2025.
Dayton Audio RSS315HO-44
Dayton Audio RSS315HO-44 Haut-Parleur Subwoofer Aluminium 700W 4+4 Ohm 85dB 20Hz - 500Hz Ø30.5cm
Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with the entire Reference Series, these subwoofers feature ultra-low distortion. Second-order, third-order and intermodulation distortion is kept extremely low thanks to 3 integrated circuits in the motor structure. The spider, made of aramid fibers and featuring an efficient ventilation system, provides uniform excursion. The anodised aluminium cone, rubber suspension and custom bowl give the speaker a unique high-end design.
The High Output (HO) loudspeakers are optimised for automotive applications or for the realisation of high power subwoofers with equalisation.
Speaker driver typeSubwoofer
Nominal diameterØ30.5cm (12")
Power handlingRMS : 700W
Max : 1400W
Impedance4+4Ω
Frequency response20Hz - 500Hz
Sensitivity84.6dB @ 2.83V/1m
Voice coil diameterØ65.5mm (2.58")
Weight11.5kg
Magnet weight4.25kg (150oz)
Thiele-Small Parameters
Resonant frequency (Fs)21.5Hz
DC Resistance (Re)6.5Ω
Voice coil inductance (Le)3.17mH
Mechanical quality coefficient (Qms)370
Electromagnetic quality coefficient (Qes)0.41
Total quality coefficient (Qts)0.37
Compliance equivalent volume (Vas)2.165 ft.³
Mechanical compliance of suspension(Cms)0.17mm/N
Force factor (BL)26.5Tm
Diaphragm mass inc. airload (Mms)327.7g
Maximum linear excursion (Xmax)14mm
Surface area of cone (Sd)507.1cm²
Materials
ConeAluminum
SurroundRubber
Voice coil wireCopper
Voice coil formerAluminum
Basket / FrameCast Aluminum
MagnetFerrite
Mounting Informations
Overall external diameterØ313.9mm (12.36")
Baffle cutout diameterØ281.9mm (11.1")
Depth146mm (5.75")
Number of fixation holes8
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume0.49ft³
Sealed F347Hz
Vented volume1.36ft³
Vented F327Hz
Speaker Power (W RMS)700.0
Speaker TypeSubwoofer
Impedance (Ω)4+4
Loudspeaker diameter (mm)305.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)14.0
Lowest frequency (Hz)20
Highest frequency (Hz)500
Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with...
