DAYTON AUDIO DMA70-8 Speaker Driver Full Range Dual Magnet 20W 8 Ohm 82.9dB 110Hz-20kHz Ø63.5mm
Delivering high efficiency and low distortion, the Dayton Audio DMA70-8 is an ideal full-range driver for modern compact speaker design. Its motor uses two neodymium magnets to create a strong, balanced magnetic field for perfect diaphragm control.
Reference : 17435
20,90 €tax incl.
17,42 € tax excl.
Last items in stock !
Shipping date: 08-05-2025.
Speaker Driver Full Range Dual Magnet 20W 8 Ohm 82.9dB 110Hz-20kHz Ø63.5mm> Dayton Audio DMA70-8 Haut-Parleur Large Bande Double Aimant 20W 8 Ohm 82.9dB 110Hz-20kHz Ø63.5mm
Delivering high efficiency and low distortion, the Dayton Audio DMA70-8 is an ideal full-range driver for modern compact speaker design. Its motor uses two neodymium magnets to create a strong, balanced magnetic field for perfect diaphragm control. The DMA70-8's careful design also reduces inductance and distortion, improving high-frequency response. The double-layer voice coil is wound on a widely ventilated aluminum support, allowing for excellent heat dissipation, power handling and low compression. The aluminum diaphragm is held in place by a rubber surround and a large frame, providing excellent mechanical damping.
Driver typeFull range
Nominal diameterØ63.5mm (2.5")
Power handlingRMS : 20W
Max : 40W
Impedance8Ω
Frequency response110Hz - 20kHz
Sensitivity82.9dB 2.83V/1m
Voicec coil diameterØ25.4mm (1")
Weight159g
Thiele-Small parameters
Resonant frequency (fS)113.7Hz
DC resistance (RE)7.5Ω
Electrical quality factor (QES)0.73
Mechanical quality factor (QMS)2.06
Total quality factor (QTS)0.50
Compliance equivalent volume (VAS)0.566L (0.02ft³)
Voice coil inductance (LE)0.5mH
Force factor (B·l)4.7T·m
Mechanical compliance of suspension (CMS)730µm/N
Surface area of cone (SD)22.9cm²
Maximum linear excursion (Xmax)±2mm
Suspension mechanical resistance (RMS)0.9T·m
Moving mass (MMD)2.5g
Moving mass (including airload) (MMS)2.6g
Surface of the diaphragm (SD)22.9cm²
Displacement volume at Xmax (VD)4.6cm³
Efficiency (η₀)0.11%
Efficiency bandwidth product (EBP)155
Materials
Cone materialAluminum
Surround materialRubber
Voice coil wire materialCopper
Voice coil former materialAluminum
Frame materialPolymer
Magnet materialNeodymium
Mounting informations
Overall outside dimensions70*70mm
Cutout diameterØ64mm
Total depth68.6mm
Bolt circle diameterØ84.1mm
Number of mountin holes4
Optimum cabinet size
Sealed volume0.71L (0.025ft³)
Sealed F3183Hz
Vented volume1.1L (0.04ft³)
Vented F388Hz
Speaker Power (W RMS)20.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)70.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)83.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)110
Highest frequency (Hz)20000
Delivering high efficiency and low distortion, the Dayton Audio DMA70-8 is an ideal full-range driver for modern compact speaker design. Its motor...
