DAYTON AUDIO TCP115-4 Speaker Driver Midbass Paper 40W 4 Ohm 87dB 55Hz - 5000Hz Ø10cm
This Dayton Audio CE32A-4 mini speaker is designed to meet a variety of needs with a wide frequency response range. It is particularly suitable for small DIY designs
Reference : 12520
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 13-05-2025.
DAYTON AUDIO TCP 115-4
Mini Loudspeakers 4Ω ⌀100mm
This DAYTON AUDIO 10cm midrange driver provides ideal high bass (54Hz) for the design of compact and musical two-way speakers. Its frequency of use up to 5000hz allows a wide choice of compatible high-frequency speakers that are easy to filter. An excellent affordable, easy-to-use speaker that will find its booster with a low-cost D-class music class amp.
Technical Specifications
Various Technical
Type loudpseakkerWoofer
PowerRMS : 40W
Impedance
Sensibility86.8dB @ 1W/1m
Response frequency55Hz - 5000Hz
Diameter coil25mm
DC resistance coil (Re)3.2Ω
Inductance coil (Le)0.97mH
Frequency resonance  (Fs)53.8Hz
mehcanical quality(Qms)3.14
Electrical quality (Qes)0.4
Total Quality coefficient (Qts)0.35
Movement air mass (Mms)9.9 gr
(Cms)0.88mm/N
Emissive area surface(Sd)50.3cm²
Force factor (BL)5.2Tm
Volume of air mass equivalent to mobile crew compliance (Vas)3.1l
Linear excursion max (Xmax)4.0mm
material membranepolypropylene
Suspension materialCaoutchouc
Magnet materialNeodyme
Total diameter108mm
Total depth65mm
Magnet Diameter80mm
Coil diameter25mm
membrane ColorBlack
Speaker Power (W RMS)40.0
Speaker TypeMidbass
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)100.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)55
Highest frequency (Hz)5000
2 reviews
Très bon rapport qualité prix
Très content de ces hauts parleurs que j'ai intégré dans un enceinte bluetooth.
https://youtu.be/xEGvq1JDTl8
This review has been posted for DAYTON AUDIO TCP115-4 Speaker Driver Midbass Paper 40W 4 Ohm 87dB 55Hz - 5000Hz Ø10cm
Very good driver
Used this for a bluetooth speaker - very good bass response from a small box.
This Dayton Audio CE32A-4 mini speaker is designed to meet a variety of needs with a wide frequency response range. It is particularly suitable for...
