DAYTON AUDIO TCP115-8 Midbass Driver Paper 40W 8 Ohm 81.9dB 55Hz - 6000Hz Ø10cm
Reference : 13881
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 26-06-2025.
Grantie 5 ans
Dayton Audio TCP115-8
TCP115 - 8
With its large capacity excursion and low resonance frequency, speaker 10cm bass DAYTON AUDIO medium can reproduce bass surprising given its size (up to 4 inches bass speaker).
The TCP115-8 also offers good performance in the midrange and lower midrange, making it a prime candidate for compact and powerful two-way fixtures. An excellent top affordable speaker, easy to use which will find its bohneur with a music class D amp at low cost.
Reply
TypeWoofer
Power handling40W RMS
80W Max
Nominal diameter4 "(10cm)
Impedance8 Ω
Frequency response55 to 6.000 Hz
coil diameter2.54 mm
DC Resistance (Re)7.8 ohms
Voice Coil Inductance (Le)1.9 mH
Resonant Frequency (Fs)59.2 Hz
Mechanical Q (Qms)2.3
Electromagnetic Q (Qes)0.54
Total Q (Qts)0.43
Diaphragm Mass Inc. Airload (Mms)10.16 g
Mechanical Compliance of Suspension (Cms)0.71 mm / N
Surface Area of Cone (Sd)50 cm²
BL Product (BL)7.4 Tm
Compliance Equivalent Volume (Vas)2.52 L
Maximum Linear Excursion (Xmax)4 mm
Cone Materialtreated paper
Surround MaterialRubber
Voice Coil Wire MaterialCCA
Voice Coil FormerAluminum
Frame MaterialSteel
Magnet MaterialFerrite
Overall Outside Diameter4.57 "
Overall Depth2.32 "
Baffle Cutout Diameter3.77
# Mounting Holes4
Bolt Circle Diameter4.25 "
Speaker Power (W RMS)40.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)100.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)82.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)55
Highest frequency (Hz)6000
Remplace très avantageusement les HP "grave" d'origine sur enceintes de bibliothèque Yamaha. Bons graves pour la taille de l'hp.
This review has been posted for DAYTON AUDIO TCP115-8 Midbass Driver Paper 40W 8 Ohm 81.9dB 55Hz - 6000Hz Ø10cm
