MONACOR MSH-116/4 Speaker Driver Midrange 40W 4 Ohm 91dB Ø11cm
Reference : 1204
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 05-08-2025.
A medium-sized speaker with outstanding reproduction qualities thanks to the materials used. The impedance of 4 Ω allows its use in embedded Hi-Fi.
Hi-Fi Medium Speaker, 4 Ω
Wide bandwidth, very low mobile mass and mobile coil on high temperature kapton support. Extra-flat bowl, decompression and core cooling that participate in the excellent impulse response.
Klang + Ton 2/01
"This loudspeaker is the surprise of the test.
Impedance (Z)4 Ω
Resonance frequency (fs)95 Hz
Maximum bandwidthfx-10000 Hz
Maximum power120 W MAX (400-5000 Hz)
Rated power (P)40 W RMS
Average sound pressure (1 W / 1 m)91 dB
Compliance susp. (Cms)0.62 mm / N
Moving mass (Mms)4.6 g
Mechanical overvoltage. (Qms)2.38
</ Span>
Electrical overvoltage (Qes)0.48
Fact. total surge (Qts)040
Volume equ. (VAS)2.7 l
DC resistance. (Re)<img src = "http://www.monacor.de/global_img/blank.gif" alt = "" width = "10" height = "1" />3.2 Ω
Force factor (BxL)4.3 Tm
</ Span>Inductance coil (The)0.18 mH
Coil diameter25 mm
</ Span>
Coil holderAlu
Linear Excursion (X MAX )± 1 mm
Transmitting surface (Sd)55 cm 2
Magnet Weight8.5ounces
Weight0.6 kg
[Img-20541-left-thickbox_default]
[Img-20540-left-thickbox_default]
[Img-20539-left-thickbox_default]
Speaker Power (W RMS)40.0
Speaker TypeMidrange
Impedance (Ω)4
Loudspeaker diameter (mm)110.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)91.0
Max Linear Excursion (Xmax) (mm)1.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)10000
