This broadband and high-performance speaker is none other than the legendary HP 95 evolution that equip the studios of the house of radio, ORTF, RAI, RTL and EUROPE 1. Opera certified, it provides a warm, clear and precise listening experience and offers a wide range of editing possibilities.
Ideal listening with a low-power amp (tube or transistor) of about 10W.
In the plane panel, the spatial presence of the sound will enchant you, the HP expresses at best its great dynamics.
In TQWT it will bring out all the finesse of your favorite listening.
This HP can be reinforced by a JBL 2405 or B & C D-32 tweeter with a single cut to 10kHz by a capability of 0.47 or 0.33 uF.
The bass can be reinforced, especially in the flat panel by the 285 or 400 SUPRAVOX cut at 100Hz.
| Sensitivity 1 W / 1m to Fs | 97 dB | Drill hole diameter | 212 mm |
| Bandwidth | 50 to 10kHz | HP Total Depth | 100 mm |
| Impedance | 8 ohms | fs | 60 Hz |
| Max. RMS | 35 W | Re | 6.5 ohms |
| Weight | 2.8 kg | qt | 0.58 |
| Suspension | 3-ply paper | Qe | 0.6 |
| Linear Excursion | 4 mm | Qm | 7 |
| Ferrite magnet | 120 mm | Vas | 80 L |
| Magnetic field | 1.5 T | bl | 5.8 |
| HP Diameter | 224 / 237mm | cms | 0.8 |
| Epsalad bowl | Alu 10mm | mms | 8.5 g |
| Distance fixing holes | 227 mm | sd | 263 cm² |
| Speaker Power (W RMS) | 35.0 |
| Speaker Type | Full range |
| Impedance (Ω) | 8 |
| Loudspeaker diameter (mm) | 210.0 |
| Diaphragm type | Paper |
| Efficiency / Sensitivity (dB) | 97.0 |
| Max Linear Excursion (Xmax) (mm) | 4.0 |
| Lowest frequency (Hz) | 50 |
| Highest frequency (Hz) | 20000 |
