FIIO BTR7 Portable Headphone Amplifier DAC 2x THX AAA-28 2x ES9219C Bluetooth 5.1 aptX HD LDAC 32bit 384kHz DSD256
With the BTR7, FiiO offers a high-performance portable headphone amplifier and DAC with a modern design. It is ideal to accompany a smartphone, in order to enjoy a high quality sound reproduction, even on the move.
By buying this product you get 20 loyalty points
Reference : 16614
209,00 €tax incl.
174,17 € tax excl.
Shipping date: 06-10-2026.
FiiO BTR7
FiiO BTR7 Amplificateur Casque DAC Portable 2x THX AAA-28 2x ES9219C Bluetooth 5.1 aptX HD LDAC 32bit 384kHz DSD256
Dual ES9219C DAC
Each channel of the BTR7 hosts an ESS ES9219C digital-to-analog conversion chip, each accompanied by a low-pass filter and amplifier. The whole is optimized within an audio architecture allowing a detailed and dynamic reproduction. In addition, these chips are capable of playing high-resolution streams and decoding MQA files.
Double THX AAA-28 amplifiers
The BTR7 is the first portable Bluetooth amplifier to use two THX AAA-28 amplifier chips in a fully balanced design, allowing for high power output.
Bluetooth 5.1
With the integration of a Qualcomm QCC5124 Bluetooth 5.1 receiver chip, you can enjoy your music without the hassle of cables. This chip is also compatible with the high-resolution transmission codecs aptX HD, aptX Adaptive and LDAC.
XMOS USB Interface
An XMOS XUF208 USB interface is associated with the BTR7's DACs, in order to receive and decode the audio stream from the device's USB-C input. This chip allows the support of high quality files, up to PCM 32bit 384kHz and DSD256, but also the decoding of MQA 8x files.
Comfortable autonomy
With its 880mAh battery, the BTR7 offers comfortable battery life for all-day use. In addition, it supports fast charging and even wireless charging.
IPS Screen
The front panel of the BTR7 features a beautiful 1.3" color IPS display. This one allows the display of the playback information, such as the level of volume, battery, gain or the audio format, for a more intuitive use.
Balanced & Single-ended
The FiiO BTR7 offers a dual output, which fits perfectly to the headphones available on the market. The first one is single-ended, in 3.5mm jack format and the second one balanced, in 4.4mm jack format. This last one allows to take advantage of a more important output power.
Control app
The BTR7 is compatible with the FiiO Control mobile application. It detects your device and lets you control it, without even taking it out of your pocket. It even offers access to additional features, such as an equalizer. It's also the best way to update your device's firmware in a very simple way.
Product typePortable DAC and headphone amplifier
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 4.4mm headphone output
Output powerSingle-ended : 150mW
Balanced : 300mW
DAC chip2x ES9219
Amplification chip2x THX AAA-28
USB interfaceXMOS XUF208
Bluetooth chipQCC5124
Bluetooth version5.1
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, aptX Adaptive, LDAC
Transmission range~ 10m
DSD up to DSD256
MQA
SNR (A-Weighted)118dB
Battery880mAh
Autonomy~ 9h
Charging time1.5h
ScreenIPS 1.3" 240*240px
CTIA compatibility
Control app
Wireless charging
Dimensions83.6 x 39.6 x 14.5mm
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9219C
Max sampling rate384kHz
Max sampling rateDSD256
top Produit
Audiophonics est une très bonne entreprise, très bon suivi client, très bon produits, livraison rapide.
J'ai acheté le Fiio BTR7 qui est un excellent DAC avec batterie, très bonne musicalité, super puissance, bref que du bon, mieux encore que le KA5.
This review has been posted for FIIO BTR7 Portable Headphone Amplifier DAC 2x THX AAA-28 2x ES9219C Bluetooth 5.1 aptX HD LDAC 32bit 384kHz DSD256
With the BTR7, FiiO offers a high-performance portable headphone amplifier and DAC with a modern design. It is ideal to accompany a smartphone, in...
