HIDIZS DH1000 DAC Balanced Portable Headphone Amplifier 2x ES9018K2M Amplifier 2x ES9601K 24bit 192kHz DSD128
The Hidizs DH1000 DAC / Portable Symmetrical Headphone Amplifier combo is the ideal companion for enjoying exceptional listening quality at home or outdoors. The device offers full compatibility and excellent audio performance thanks to a rigorous design to accompany you in your listening and reveal the smallest details of your music.
Reference : 14505
125,00 €tax incl.
104,17 € tax excl.
Hidizs DH1000
DAC Balanced Portable Headphone Amplifier 2x ES9018K2M 2x ES9601K 24bit 192kHz DSD128
DAC Amplificateur Casque Symétrique Portable 2x ES9018K2M 2x ES9601K 24bit 192kHz DSD128
Dual ES9601K Amplifier
The amplification circuit embeds two ES9061K chips capable of developing significant power to accompany the vast majority of headphones on the market, up to 600 Ohm, while ensuring accurate and faithful reproduction.
Dual ES9018K2M DAC
The Hidizs DH1000 relies on a pair of high-performance DAC ESS ES9018K2M chips for digital-to-analog conversion, with each chip processing the audio stream of a single channel. In addition, these chips support high-resolution audio files up to 24bit 192kHz PCM and DSD128.
Low noise audio
The DH1000's carefully optimised PCB benefits from gold-plated circuitry for excellent electrical conductivity and a structure that significantly limits interference that can have a negative impact on the integrity of the audio signal and consequently on sound reproduction. With an excellent analog output stage with a signal-to-noise ratio (SNR) of 122dB, the DH1000 offers incredibly accurate and rich sound reproduction.
Outstanding sound quality
With an extended frequency response from 0Hz to 50kHz and 120dB stereo separation, the Hidizs DH1000 is able to unveil a sound of great transparency and separation of high, mid and low frequencies, allowing previously imperceptible details to be revealed for an unparalleled immersion in the heart of your music.
Quadruple high quality clocks
The DH1000 carries no less than 3 ultra low noise clocks for signal transmission and one for measurements. These allow a drastic reduction of the jitter and thus a significant limitation of the distortion.
A consequent power to match the most demanding headphones
Thanks to its two ES 9601K amplifier chips, the DH1000 is capable of accompanying most headphones on the market, including demanding models with an impedance of up to 600 Ohm. The Hidizs amplifier / DAC benefits from more than one dual headphone output, with an unbalanced 3.5mm jack and a balanced 2.5mm jack.
Dual USB Output
The DH1000 has two independent Micro USB inputs for power line and data transfer. This makes it possible to use the device on the move, with a power bank connected, while still listening to your music.
Maximum compatibility
With its advanced decoding capabilities, the DH1000 supports many audio formats including FLAC, APE, WAV, ALAC, Apple Lossless, DSF, DSIFF with sample rates up to PCM 24bit 192kHz and native DSD128.
Product typeBalanced headphone amplifier / DAC
DAC Chip2x ESS ES9018K2M
Amplification chip2x ES9601K
Supported sampling ratesPCM up to PCM 24bit 192kHz
DSD up to DSD128
Frequency response0Hz - 50kHz
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 2.25mm
Inputs2x Micro USB
System compatibilityAndroid
iOS
Windows
Mac
ASIO compatibilityWindows 7 / 8 / 10
Autonomy10h
THD+N117dB
Channel separation120dB
SNR-122dB
Output powerSingle-ended Jack 3.5mm headphone output : 120mW 32 Ohm
Balanced Jack 2.5mm headphone output : 150mW 32 Ohm
Housing materialAluminium alloy
GlassDouble sided 2.5D tempered glass
Dimensions121 x 68 x 13mm
ColorNoir
Package1x Hidizs DH1000
1x USB-A to Micro USB cable
1x USB OTG Cable
1x USB-C to Micro USB cable
OutputJack 2.5mm
OutputJack 3.5mm
The Hidizs DH1000 DAC / Portable Symmetrical Headphone Amplifier combo is the ideal companion for enjoying exceptional listening quality at home or...
