XDUOO XP-2 Portable Headphone Amplifier and DAC Bluetooth 5.0 aptX AK4452 24bit 192kHz
The xDuoo XP-2 is a portable amplifier and DAC that can accompany you throughout your travels or even at home, to offer you the best of your music. This offers an AKM AK4452 conversion chip supporting sample rates up to 24bit 192kHz, Bluetooth 5.0 with aptX and a SA9123 USB interface.
Reference : 13088
115,00 €tax incl.
95,83 € tax excl.
xDuoo XP-2
Portable Headphone Amplifier and DAC Bluetooth 5.0 AK4452 24bit 192kHz
xDuoo
xDuoo XP-2 Bluetooth 5.0
Bluetooth 5.0
The XP-2 supports the latest Bluetooth 5.0 version bringing many improvements in wireless transmission. Thus, the range allowed by this evolution is doubled, and the transmission rate can now reach 2Mbps. As for consumption, nothing to fear since this new version has no impact on this parameter.
This speed allows you to enjoy high quality audio playback and extremely stable transmission. In addition, this version also allows the device to detect radio frequency interference in the 2.4GHz band in order to modify the communication channel accordingly to preserve transmission performance.
Finally, it also supports the Bluetooth aptX protocol, also allowing a very good transmission rate but above all excellent signal stability for accurate reproduction.
Quality USB input
The xDuoo amplifier / DAC benefits from a high-performance SA9123 USB interface. This works asynchronously and also supports high resolution files up to 24bit 192kHz in PCM. Something to really enjoy your favorite songs, without limit.
xDuoo interface USB SA9123
xDuoo XP-2 compatible android et iOS
iOS and Android compatible
The xDuoo XP-2 can be combined with many Smartphones, be they Android or iOS, so you can enjoy its amplification and conversation power, as well as its amazing sound reproduction, whether you're on the go or at home. In addition, to allow you to enjoy the best of your music, it supports high resolution files up to 24bit 192kHz.
In the case of the use with an iPhone it will be necessary to use the Camera Kit of Apple.
When using with an Android device, simply use an OTG USB cable.
An amplifier and DAC with multiple features
Gain ajustable : 2 niveaux
The xDuoo XP-2, to fit all headphone types, headphones and EMI, offers two-level gain adjustment. A switch on the side of the unit changes from +3dB to +9dB.
DAC Out
Micro USB Input, 3.5mm Jack Auxiliary or Bluetooth 5.0, the XP-2 offers many possible inputs. But you can also connect the XP-2 to active speakers, to enjoy only its high quality Digital to Analog conversion.
Auxiliary Input
You are not interested in transmitting your audio files via Bluetooth? The XP-2 also features a 3.5mm Auxiliary Jack input.
Amplification circuit
The amplification stage adopts an OP+BUF architecture allowing it to provide high power. The power supply provides +/-5V through a high efficiency conversion circuit, allowing the amplifier to adapt to the very large majority of headphones. The output circuit adopts an OCL structure and therefore no coupling capacitor is required. This design offers deep, clean bass and a rich sound.
DACAKM AK4452
Bluetooth version5.0
Supported Bluetooth protocolsaptX, SBC, AAC
Output power245mW @ 32 Ohm
Recomanded output impedance16 - 300 Ohm
Supported sampling rate24bit 192kHz
THD+N0.008% @ 1kHz
Adjustable gain+3dB / +9dB
Frequency response10Hz - 100kHz (+/-0.5dB)
Battery capacity3.7V 1800mAh
AutonomyAux input > 15h
Bluetooth > 12h
USB input > 8h
CompatibilityAndroid with OTG support
Windows XP, 7, 8, 10 (driver needed)
Mac OS / iOS
Dimensions10.5 x 5.6 x 1.5cm
Weight115g
ColorNoir
InputJack 3.5mm
OutputJack 3.5mm
2 reviews
Un bon kick
Bien que tout soit très serré dans la boite, les câbles et notices sont bien emballés. Le XDUOO est petit, léger mais de bonne facture. Le « pairing » s’est fait sans problème avec mon iPhone et mon iPad.
En le connectant à mon vieil ampli Luxman, il a pris un bon kick. Je peux pousser un peu plus le volume sans pour autant être à fond, c’est agréable. Le son est propre, un peu plus de basse
à première vue. En sortie de mon PC, je peux également mieux entendre certains fichiers audio de piètre qualité, mais nécessaire à mon job. Globalement très satisfaite pour l’instant.
This review has been posted for XDUOO XP-2 Portable Headphone Amplifier and DAC Bluetooth 5.0 aptX AK4452 24bit 192kHz
Un vrai "baroudeur"
La sonorité que délivre ce petit amplificateur est dense, faite de plénitude, de matière, avec des teintes chaudes et fauves jamais fatiguantes même en écoute prolongée.
Le médium est charnu, doux et varié. Les aigus n'en font jamais trop et restent bien intégrés à la façon d'un "Large bande". Avec lui la musique est retransmise avec neutralité sans accident. Il reste assez droit et énergique et ne cherche jamais à être surdéfini.
Le registre grave est absolument magnifique. On n'attend pas d'un si petit objet autant de grandeur dans le bas et le milieu de l'espace sonore. Quelle santé ! Quel coffre ! C'est grandiose, sombre à souhait quand il le faut et plein de saveurs. Il ne recule pas devant une cathédrale de sons énorme et sait donner des couleurs à un quatuor à cordes.
Avec lui, la musique a quelque chose de soyeux, de très séduisant et d'élégant parce qu'elle semble provenir d'un objet d'où l'électronique et le numérique sont absents.
Le mariage sans fil ou Bluetooth avec ses petits camarades se fait le plus simplement du monde et reste extrêmement stable.
Son format et son ergonomie sont proches de l'idéal pour la hifi nomade. Il est taillé pour l'aventure...
Formidable !!
The xDuoo XP-2 is a portable amplifier and DAC that can accompany you throughout your travels or even at home, to offer you the best of your music....
