FX-AUDIO PH-01 Portable Headphone Amplifier 2x OPA NE5532 Black
This FX-Audio PH-01 is a small portable headphone amplifier, simple but very powerful. Integrating an amplification circuit with two NE5532 AOPs mounted on DIP8 and therefore interchangeable, it offers a very nice musicality and a significant power gain.
Reference : 13460
29,90 €tax incl.
24,92 € tax excl.
FX-Audio PH-01
Amplificateur Casque Portable 2x AOP NE5532
This FX-Audio PH-01 is a small portable headphone amplifier, simple but very powerful. Integrating an amplification circuit with two NE5532 AOPs mounted on DIP8 and therefore interchangeable, it offers a very nice musicality and a significant power gain. The amplifier also offers two gain levels (Low / High) to fit the vast majority of headphones. It is therefore perfectly adapted to offer a boost to a DAP or smartphone when you are on the move. Indeed, its small dimensions allow the PH-01 to easily slip into a pocket and be forgotten.
Warning: Opening the unit and changing the AOPs will void the warranty.
Input1x Jack 3.5mm
Output1x Jack 3.5mm
OPA2x AOP5532 (mounted on DIP8)
Frequency response20Hz - 20kHz (+/-0dB)
THD0.0001%
SNR125dB
Headphone output THD0.07%
Output power65mW @ 16 Ohm, 89mW @ 32 Ohm, 95mW @ 64 Ohm, 69mW @ 120 Ohm, 29mW @ 300 Ohm
Power supply (battery charge)5V 1A via Micro USB
Dimensions9.5 x 5.3 x 1.3cm
Weight75g
Package1x FX-Audio PH-01
1x Jack 3.5mm to Jack 3.5mm cable
1x USB-A to Micro USB cable
InputJack 3.5mm
OutputJack 3.5mm
This FX-Audio PH-01 is a small portable headphone amplifier, simple but very powerful. Integrating an amplification circuit with two NE5532 AOPs...
