XDUOO XD05 BAL 2 Portable Balanced DAC Headphone Amplifier
The new XDUOO XD05 BAL 2 portable DAC headphone amplifier is a device capable of delivering excellent performance for a highly enjoyable listening experience. It relies on no less than two ES9038Q2M DAC chips and an XMOS XU316 interface for its conversion stage, while its preamplification stage features two AOP1612s. These audiophile components enable it to support sampling rates up to PCM 32Bit 768kHz and native DSD up to DSD512, as well as offering output power up to 1500mW @ 32 ohm.
By buying this product you get 42 loyalty points
Reference : 19988
429,00 €tax incl.
357,50 € tax excl.
Shipping date: 03-04-2026.
xDuoo XD05 BAL 2 Portable Balanced DAC Headphone Amplifier 2x ES9038Q2M XMOS Bluetooth 5.0 32bit 768kHz DSD512 Silver
Photo du XDUOO XD05 BAL 2
The new xDuoo XD05 BAL 2 portable DAC headphone amplifier is a device capable of delivering excellent performance for a highly enjoyable listening experience. It relies on no less than two ES9038Q2M DAC chips and an XMOS XU316 USB interface for its conversion stage, while its preamplification stage features two OPA1612s. These audiophile components enable it to support sampling rates up to PCM 32Bit 768kHz and native DSD up to DSD512, as well as offering output power up to 1500mW under 32 ohm.
There's also Bluetooth 5.0 functionality, numerous inputs, two headphone outputs (balanced 4.4mm jack and single-ended 6.35mm jack) and a 3.5mm AUX line output. A 5000mAh lithium-ion battery supplies power for up to 12 hours of nomadic listening. XDuoo offers a portable device that can be adapted to a wide range of uses.
xDuoo XD05 BAL 2: 2x DAC ESS9038Q2M + XMOS XU-316
The combo of ESS9038Q2M DAC chips coupled with an XMOS XU-316 USB interface enables the xDuoo XD05 BAL 2 to support high-resolution streams up to PCM 32bit 768kHz and DSD512. The ESS DAC chips also offer an SNR of 120dB.
SNR du XDUOO XD05 BAL 2
Système d'horloge du XDUOO XD05 BAL 2
xDuoo XD05 BAL 2: optimized clock system
Two low-noise crystal oscillators combined with a new CPLD provide a THD+N of just 0.00065% and very low jitter for improved performance.
xDuoo XD05 BAL 2: audiophile architecture
The xDuoo XD05 BAL 2 uses only audiophile components and a balanced architecture.
Architecture du XDUOO XD05 BAL 2
xDuoo XD05 BAL 2: high output power
The xDuoo XD05 BAL 2's output power of 1500mW under 32 ohm load enables it to drive a large number of headphones available on the market. In fact, it can drive headphones with impedances from 32 to 300 ohm without difficulty.
La puissance de sortie du XDUOO XD05 BAL 2
xDuoo XD05 BAL 2: OPA1612 DIP8
DIP8 mounting of the OPA1612 OPAs means they can be easily replaced to change the texture of the sound to suit the user's taste.
Des AOP DIP8 pour le XDUOO XD05 BAL 2
Fonction Bluetooth du XDUOO XD05 BAL 2
xDuoo XD05 BAL 2: Bluetooth 5.1
Bluetooth 5.1 functionality ensures reliable, stable wireless connectivity, with support for standard SBC and AAC codecs, as well as high-definition codecs aptX, aptX LL, aptX HD and LDAC, making it easy to access streaming platforms via a smartphone.
xDuoo XD05 BAL 2: 5000mAh battery
The xDuoo XD05 BAL 2's 5000mAh battery, which supports rapid charging (3h), provides autonomy from 9h to 24h depending on use, making it the perfect ally for audiophiles on the move.
Batterie du XDUOO XD05 BAL 2
xDuoo XD05 BAL 2: bass-boost function
If the bass on your headphones isn't powerful enough, you can transform it with two gain settings that boost low frequencies by 3 to 6dB.
Fonction bass-boost du XDUOO XD05 BAL 2
xDuoo XD05 BAL 2 overview
Aperçu du XDUOO XD05 BAL 2
1Single-ended 6.35mm jack headphone output
2Balanced 4.4mm jack headphone output
3Display
4Power on
5Turbo function
6Bass boost function
7Volume control
83.5mm jack analog input/output jack (AUX)
9Operating mode selection
10USB-C input
11AES/EBU input
12USB-C charging port
13Coaxial input
Product typePortable DAC and headphone amplifier
DAC chips2x ESS9038Q2M
AOPOPA1612
Inputs1x USB-C
1x AES
1x Coaxial
1x AUX 3.5mm jack
Outputs1x Single-ended 6.35mm headphone output
1x Balanced headphone output, 4.4mm jack
1x AUX jack 3.5mm output
Supported sample ratesUSB: PCM up to 32Bit 768kHz, DSD up to DSD512, MQA
AES / Coaxial: PCM up to 24Bit 192kHz, DSD DoP64
Supported bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
Frequency responseUSB / Coaxial: 20Hz-20kHz (+/-0.5dB)
Amp: 10Hz-100kHz (+/-5dB)
ScreenOLED 0.91"
System compatibilityWindows, Linux, Mac OSX IOS, Android
Turbo function+6/15dB
Bass function+6dB
Output power1500mW @ 32 ohm
THD+N0.0012% @ 1kHz
S/N120dB
Crosstalk≥ 72dB
THD+N0.00065% @ 1kHz
S/N120dB
Crosstalk≥ 100dB
AUX 3.5mm Jack output
Output level2Vrms
THD+N0.0008% @ 1kHz
S/N120dB
Crosstalk≥100dB
Power supplyVia USB-C port
Battery3.8V/5000mAh
Battery lifeUSB IN: 9h
SPDIF IN: 12h
Aux IN: 24H
Battery charging timeQuick charge: 3h
Slow charge: 6h
Dimensions132 x 75 x 22mm
Weight300g
Package1x xDuoo XD05 BAL 2
2x USB-C cable
1x USB-C to Lightning cable
1x USB-A to USB-C adapter
1x AES/EBU cable
1x 6.35mm jack to 3.5mm jack adapter
InputJack 3.5mm
InputAES/EBU
OutputJack 3.5mm
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorSilver
ClassN/A
XDUOO XD05 BAL 2 Portable Balanced DAC Headphone Amplifier 2x ES9038Q2M XMOS Bluetooth 5.0 32bit 768kHz DSD512 Silver
The new XDUOO XD05 BAL 2 portable DAC headphone amplifier is a device capable of delivering excellent...
