Marc S.
Ce Bliss est incroyable en tant que préamplificateur classA HDG. Je l'utilise avec le DAC Holo Sring3 L2 et pour la...
Johan v.
Good after software update
Not bought here for practical reasons it would not read anything after track 31 and after a helpful email from Shanling and a...
Johan v.
My favorite hookup wire
Strips easely soldering well heat resistant great to work with
Customers reviews - There are 19589 reviews.
Roeland T.
Female 4 Poles Jack 2.5mm Socket Gold Plated This 2.5mm female jack socket is ideal for PCB mounting and will allow you to add an efficient connectivity to a DIY project. Its contacts are gold plated and ensure a very good...
Close to what I need
This is a Female Socket that provides 4 connections. A 2.5mm diameter Jack plug with 4 Poles (3 isolation rings) does fit in this socket, However, only 3 Poles of the Jack plug make contact: the Pole furthest from the tip does not connect to the gold plated pin as I had expected.
Teemu M.
Sound quality isn't great, the board is noisy
It has high noise, bluetooth stopped working quite soon after the purchase (2018), loud crosstalk from line input while bluetooth and so on. Cannot use with all the attachments, like Jab3 and batter pack because they utilize same connector. It is feature packed product with great expectations, but a disappointment and would not recommend purchasing this product. While it works, it is cumbersome and just poor quality.
That said, purchased it 2018 and now 5 years later it still works apart from the bluetooth so in this sense it's fine. Just do not expect anything from such cheaply made product.
Teemu M.
Seems fine,
Seems fine, no issues, been in use about 5 years now. Not daily but still.
très bon; recommandable
J'ai eu en petit format des ampli intégrés smsl ; fx audio et audiophonics acquis sur ce même site . Ce aiyima est meilleur que ce cités précédemment . Son très naturel et détaillé ; très bonne spatialisation ; les correcteurs grave et aigu sont très juste et quelle transparence ! Impression d'écouter un ampli beaucoup plus cher . A ce prix difficile de faire mieux .
Matthew B.
OPA1656 Dual OPA DIP8 (Unit) This OPA1656 OPA from Texas Instrument offers very good performances for audio use. It has a very good dynamic range and a low level of harmonic distortion. Taking advantage of...
Exact Replacement Adaptor plus op amp
This was really a convenient replacement. Plug it in and it worked.
The chip was aligned and soldered neat and clean. Nice!!!
Communication and shipping - Top Notch.
Great.....
John B.
Connectivity
A great device, sound brilliant and great UI. If i have any issue at all its the inability to simultaneously have an Analogue and Digital Output. It possible to have both the XLR and RCA active but for some reason when this is done the XLR output drops to RCA level
LAURENT L.
Gros gain
En remplacement d'une Legrand de base le gain est considérable même sur un système haut de gamme, un vrai apport en terme de lisibilité, de précision sans nuire à la musicalité et aux timbres (contrairement au Rhodium qui peut faire apparaitre des duretés).
Un superbe upgrade pour un investissement très doux !
VIBORG BP-603 (G) Speaker Terminals Pure Copper Silver / Gold Plated 24k 3μ Ø4.5mm (Set x4) With its BP-603 (G), Viborg offers exceptional loudspeaker terminals, thanks to a design using particularly high-end materials.
la suite
Sur lez ETI c'est Cuivre pur (IACS 102%)
Sur celles c'est du laiton recouvert d'argent et de cuivre (ou or me souviens plus)
C'est ce qui explique la différence et aussi le prix.
son boucher
Par rapport aux ETI pur cuivre le son est boucher alors que les autres laisse tout passer
Sur un système montant et manquant de medium ça doit convenir mais pas pour moi d'où 3* sinon belle construction et présentation
C'est la même.probleme pour les bananes aussi
Andoni G.
Conector supremo low cost
Tengo conectores que cuestan seis veces más y prefiero este.
Andoni G.
Good cable
Es un cable muy grueso y difícil de doblar. La calidad percibida es superior
Nathalie M.
Précis & Musical
Fonctionne très facilement en Bluetooth (mais juste en 48 kHz...) en délivrant une puissance modeste mais plutôt correcte pour 20-25 M2.
Ne chauffe pas du tout et sans aucun bruit parasite.
Pas encore testé en Hi-Res, via USB ou fibre Optique mais déjà étonnée par la qualité musicale restituée.
Guillaume B.
Excellent connecteur
Remplace un connecteur Iego sur un cable Furutech alfa. Très bien conçue et surtout gain immédiat en musicalité, impression de débouchage du système. Pas d'agressivité. Pour l'alim Farad u streamer. Accuphase E800
Ioannis K.
ATAUDIO KING WOLF RCA Interconnect Cable 6N OFC Copper Shielded Gold Plated 1m (Pair) These ATAudio King Wolf RCA cables feature quality construction with OFC 6N insulated copper conductors for excellent signal transmission. The braided copper shielding...
Excellent sound and quality
It works as intended, it sounds great connecting my DAC to my integrated Amplifier.
Ioannis K.
Great usb cable!
The cable is great. Very good construction and quality.
Ioannis K.
TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Silver Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and preamplification functions. Embarking...
Excellent DAC/head phone pre-amp
Today, after the ultra fast shipping from audiophionics, i had the pleasure of experiencing the Topping DX3Pro+, and let me tell you, it's a game-changer. As someone who values both sound quality and versatility, this DAC truly impressed me. For the money it costs, its superb.
Hachadourian F.
Knob Aluminium Notched Shaft 25x13mm Ø6mm Black This black aluminium knob with a diameter of 25mm and a depth of 13mm has a 6mm diameter notched pin. A perfect button for mounting on a DIY project or as a replacement for a...
excellente qualité et esthétique à un prix très correct !
Cao Hai N.
Excellent RQP
Excellent! Du gain et de la musicalité. Qualité/Prix imbattable!
Henry G.
Automatic Power Suplpy Switching Module This power supply switching module automatically switches an amplifier on and off when the module receives an audio signal with a level above 500mV.
Remplit parfaitement sa fonction, compact. Dommage que la modification de la tempo ne puisse se faire que par un changement de capa d'un condensateur.
JULIUS L.
I LOVE THIS AMP
I have also the LD1+ but MKIV SE is just so much better at everything.
The amount of bass,midbass and midrange is surprising great pairing with my Grado RS1x razor sharp neutron star dense bass pure audio bliss. There is plenty of power that I will probably never need this much but good to have it just in case.
There is slight microphonics but proper placement away from electromagnetic fields from other electronics helps.
Those tubes improved after 60 hour so much better separation of layers, better details everything.
Delivery and sent was fast and reliable highly recommended audiophonics is GREAT.
I will be back in the future for sure!
Pratique
Comme son jumeau en iec, ce connecteur est super pratique pour les câble de grosse section et pour gagner de la place sans abîmer le matos. Bonne restitution .
Pratique
Pratique pour gagner de la place derrière un meuble et bon accueil pour un elecaudio cs361 de 17 mm de diamètre.
Bonne restitution du signal.
DDHifi TC07S USB-C Cable Pure Silver / OFC Copper OTG 50cm The DD TC07S cable consists of a male USB-C OTG connector on both sides. The cable features an optimized structure with perfect separation of the data and power conductors to...
sous des cables
LAURENT G.
ETI KRYO Silver Plated Tellurium Copper Binding Post Ø17mm x 52mm (Set x4) The ETI Kryo are top of the range terminal blocks designed with exceptional components. It features a Tellurium Copper conductor with Silver plating for maximum conductivity and...
Excellents borniers
LAURENT G.
Pratique et bonne qualité
Bonne qualité pour le prix.
Je conseille vivement.
LAURENT G.
Guillaume F.
SHANLING M0 PRO Compact HiFi Digital Audio Player DAP DAC 2xES9219C Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD Green Shanling offers with the M0 Pro a technical and aesthetic evolution of the M0 high fidelity digital player. This Pro version benefits from an improved digital/analog conversion...
DAP Shanling M0 Pro
Laurent M.
Très très bon câble H.P
Sur ma config;
les connecteurs :
Le résultat est magnifique !
C'est beau !
très bon
très bon
toujours content
ca dépends du système
Anton N.
Excellent bornier.
Excellente fiche banane
Emmanuel A.
Haut de gamme
Joris J.
Loose physically connected
Joris J.
Superb reclocker
Eugen M.
TSP facile
Eugen M.
Très surpris en bien
Joris J.
Exceptional value
Almost for free.
Philippe K.
ASTELL&KERN KANN MAX Digital Audio Player DAP HiFi 4x ES9038Q2M Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Gray The KANN series is a line of portable digital music players, particularly popular with audiophiles for their performance focused on high output and clear sound. The KANN MAX,...
Erik J.
naturel
Thierry V.
Surprenant!
Rimantas S.
Nice little DAC
Nothing to complain about.
Jean L.
Très bon RQP
