Filters
Categories level 1
Brand
In stock
Johannes R.
Fosi Audio P4 Preamp
Très approprié à mon avis. J'ai équipé les monos V3 d'Audiophonics OPA1642. Parfait pour moi ! DAC est un Soekris...
Patrice P.
Haute valeur musicale ajoutée
Après plus d'un mois d'écoute, ce DAC révèle sa vraie nature très musicale et analogique. Il est aussi très précis,...
philippe C.
Dynamique
J'ai essayé ce filtre qui m'apporte du silence, de la dynamique, des détails et un médium plus naturel. C'est...
New products
  • Ref : 20721
    In Stock
    The Douk Audio DAC-Q11 is a unique device featuring two switchable DAC chips. It features an ESS ES9038Q2M chip and an AKM AK4493 chip. Each of these chips supports high-resolution sampling rates up to PCM 32bit 384kHz and DSD256. Users can therefore enjoy both the renowned dynamics of ESS chips and the refined tones of AKM chips.
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 20715
    In Stock
    Sommercable's Epilogue cables feature two Neutrik XLR connectors, male on one side and female on the other. The cables are of high quality design and are based on four copper conductors with a cross-section of 0.14mm². Each of these conductors is covered with a thin layer of carbon before being wrapped in insulation. This layer of carbon not only...
    139,00 € 115,83 €Ex.
    In Stock
  • Ref : 20716
    In Stock
    Viablue's 24k gold-plated T8 banana plug contacts allow you to make your own cables by soldering the contact directly to the conductor. You can also screw these plugs to the body of Viablue T8 banana plugs, allowing you to replace faulty connectors, for example.
    47,90 € 39,92 €Ex.
    In Stock
  • Ref : 20717
    This LHY Audio 3.3V 1.5A low-noise voltage regulator module uses the recommended integration method of the Analog Devices LT3042 + PNP high-end regulator. This provides near-zero noise voltage regulation and a high output current of 1.5A. It can therefore deliver a pure power supply for DACs, high-precision measuring instruments, noise-sensitive RF...
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 20719
    The 7Hz Artemis39 is a compact portable DAC, equipped with an ESS ES9039Q2M chip offering rich, detailed sound and supporting high-resolution audio streams up to PCM 32bit 384kHz and DSD256. What's more, this DAC ensures low power consumption, which combined with an 1100mAh battery, provides comfortable autonomy with up to 10 hours of continuous playback.
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 20705
    In Stock
    This IEC C13 Neotech NC-P303II connector will enable you to design your own high-performance cables. It incorporates G-UPOCC composite contacts, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical...
    In Stock
  • Ref : 20713
    LAiV Audio Harmony GaNM power amplifiers represent excellence in power amplification, coming in the form of two mono blocks exploiting gallium nitride (GaN) transistors for 200W of amplification at 8Ω per block, offering uncompromising sound quality. The meticulous attention paid to every aspect of the Harmony GaNM, from its ultra-low-noise power...
    5 129,00 € 4 274,17 €Ex.
    In Stock
  • Ref : 20714
    The SMSL VMV A1 Pro is an innovative amplifier that uses Gallium Nitride (GaN) transistors to deliver 2x160W of amplification at 4Ω. Its versatility also allows it to operate in pure mono mode, delivering an impressive 400W into 4Ω. Every component of the VMV A1 Pro has been meticulously selected to achieve exceptional audio performance, with...
    529,00 € 440,83 €Ex.
    In Stock
  • Ref : 20710
    In Stock
    The Keces Ebravo is a versatile audio streamer designed to deliver a high-quality music listening experience. Compatible with many popular streaming services such as Spotify, Tidal and Qobuz, as well as UPnP and DLNA network protocols, it gives you easy access to your favorite music. It can handle audio signals up to PCM 24bit 192kHz. The Ebravo supports...
    599,00 € 499,17 €Ex.
    In Stock
  • Ref : 20711
    In Stock
  • Ref : 20748
    This low-noise DNR resistor from Dayton Audio is mainly used in L-PAD loudspeaker crossovers and attenuators. This 20 Ohm resistor has a high thermal conductivity ceramic core, internal solder assembly, OFC copper wires and a low inductance wirewound, making it perfectly suited to DIY assembly.
    1,49 € 1,24 €Ex.
    In Stock
  • Ref : 20749
    This low-noise DNR resistor from Dayton Audio is mainly used in L-PAD loudspeaker crossovers and attenuators. This 4 Ohm resistor has a high thermal conductivity ceramic core, internal solder assembly, OFC copper wires and a low inductance wirewound, making it perfectly suited to DIY assembly.
    1,49 € 1,24 €Ex.
    In Stock
  • Ref : 20750
    This low-noise DNR resistor from Dayton Audio is mainly used in L-PAD loudspeaker crossovers and attenuators. This 2.4 Ohm resistor has a high thermal conductivity ceramic core, internal solder assembly, OFC copper wires and a low inductance wirewound, making it perfectly suited to DIY assembly.
    1,49 € 1,24 €Ex.
    In Stock
  • Ref : 20757
    In Stock
    This WIMA MKP 10 capacitor has good filtering capacity, making it suitable for a wide range of applications. It also benefits from a quality design ensuring a long service life, even at high temperatures.
    0,50 € 0,42 €Ex.
    In Stock
  • Ref : 20712
    In Stock
    The Douk Audio A5 Pro integrated amplifier, big brother of the A5, is a small amplifier based on audiophile components with a singular aesthetic. It's based on a TPA3255 amplifier chip and OPA NE5532, enabling it to deliver output power levels of up to 2x 120W under 4 ohm with the supplied power supply. Its PFFB circuit reduces distortion and greatly...
    144,00 € 120,00 €Ex.
    In Stock
