0.8m long pre-cut cable
Refurbished product - Grade S
This product is sold in the form of 0.8m offcut pieces of cable.
The Neotech cable from the NEVD series has been carefully designed specifically for the transmission of digital audio signals. The main characteristic of digital audio signals is the transmission of very high frequencies. Neotech has therefore focused on minimizing signal loss.
The NEVD-1001 is an excellent coaxial digital cable with 75Ω impedance, offering wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an exceptional design, with a pure OCC Silver conductor and a particularly effective quadruple shield consisting of Polyethylene foam, Copper-Mylar foil, microporous PTFE and SP-OFC braid.
Product type | Coaxial cable |
Impedance | 75Ω |
Conductor | OCC pure Silver |
Quad shielding | Polyethylene foam Cu-Mylar foil Microporous PTFE Braided SP-OFC |
Diameter | Ø7.6mm |
Length | 0.8m |
Diameter (mm) | 7.6 |
Length (m) | 0.8 |
Number of conductors | 1 |
Insulation material | PTFE |
Insulation material | PE |
Shielding | Yes |
Section (mm²) | N/A |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | None |
Ground / Shielding | Yes |
