Expandable Braided Nylon Sleeve 6-12mm Gray
This grey braided nylon sheath will effectively cover your cables and give them greater mechanical resistance. This has an adjustable diameter from 6mm to 12mm.
4.5 / 5
Reference : 3189
0,70 €tax incl.
0,58 € tax excl.
Shipping date: 06-05-2025.
Gaine vendue au mètre
This grey braided nylon sheath will effectively cover your cables and give them greater mechanical resistance. This has an adjustable diameter from 6mm to 12mm.*
For easier mounting we recommend using cables up to 6mm in diameter with this sheath.
Depending on the diameter of the cable to be sheathed, the effective sheath length can be reduced by up to 30%. We therefore recommend that you order a sheath length at least 30% longer than the length of your cable.
SHEATH LENGTH DEPENDING ON CABLE DIAMETER (FOR 1M CABLE)
Cable diameterSheath length required
Ø6mm1m
Ø8mm1.08m
Ø10mm1.15m
Ø12mm1.3m
Sheath materialBraided Nylon
ColorGray
Acceptable cable diameter6m to 12mm
Sold by the meter-
ColorGray
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)12.0
2 reviews
Bonne qualité
Bon rapport qualité prix : fait le job !
This review has been posted for Expandable Braided Nylon Sleeve 6-12mm Gray
Bon rapport qualité/prix
Bon rapport qualité/prix même si un peu fragile.
Bonne capacité d'extension mais s'effiloche très facilement ! Je conseille de mettre un scotch à l'extrémité libre pendant la mise en place et le raccordement du câble gainé. On peut laisser celui-ci en place s'il est recouvert ensuite sinon, il vaut mieux un peu de colle cyanoacrylique
This grey braided nylon sheath will effectively cover your cables and give them greater mechanical resistance. This has an adjustable diameter from...
