Dommage que ce très bon produit ne tienne pas plus longtemps, car moins de 4 ans, c'est court. Audiophonics confirme que les diodes donnent un message come quoi le lecteur réseau est HS...
This version based on the DietPi operating system requires computer knowledge.
Streamer USB Interface Ultra Low Noise + Case
The Allo USBridge Signature Player is based on a Raspberry Pi Compute Module 3+ SBC (Single Board Computer), offering this system great versatility. The DietPi operating system is pre-installed, and will allow you to easily access your entire audio library on a network or locally (USB storage).
The purpose of this module is to reduce noise on the USB bus as much as possible in order to provide the purest, most accurate and richest sound reproduction possible. For this purpose, the USBridge Signature includes an excellent USB control chip from TI and the Ethernet circuit is completely separate from the USB circuit, thus limiting interference. In addition, noise has been reduced on each power rail through the use of more than 30 LDO controllers. Even the power rail of the Micro SD port has its own LDO. Thus, the module does not include any switching elements that can generate noise.
As the USBridge Signature is based on a Pi Compute, Allo has chosen to integrate all the available connectivity on a standard Raspberry Pi, namely a GPIO port, USB-A, HDMI and a Micro SD slot. Therefore, anything that works with a Raspberry Pi will work with the USBridge Signature.
This Aluminium case has been specially designed by Allo to cover the USBridge Signature, protecting it from dust and shocks. Tightly stretched, the housing allows access to all the USBridge Signature connectors.
The USBridge Allo is delivered mounted in the housing.
Product type | Streamer |
SBC | Raspberry Pi Compute Module 3+ |
OS | DietPi |
Inputs | 3x USB-A 2.0 Host 1x Gigabit Ethernet RJ45 1x Micro SD slot |
Outputs | 1x USB-A (delivers up to 900mA) 1x HDMI |
Supported sampling rates | PCM up to 768kHz DSD up to DSD512 (DSD1024 theoretically possible) |
Ethernet chipset | AX88179 |
Ethernet bandwidth | 330Mbs |
USB protection | All USB Host ports include built-in overload protection |
Alimentation | 5V 3A via USB-C (sold separately) |
Certification USBridge Signature | FCC, CE |
Case material | Aluminium |
Color | Black |
Dimensions | 125x154x55mm |
Weight net | 600g |
Input | Micro SD |
Input | RJ45 |
Output | HDMI |
DAC / ADC Chip | NC |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Max sampling rate | DSD1024 |
Color | Black |
Remote Control | No |
Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | AirPlay |
Average votes 5.0 / 5 12 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Hugues L.
Yohann A.
Hervé C.
J L T.
Hugues L.
