Streamer Raspberry Pi & DAC TCXO
The Audiophonics team is proud to introduce the RaspDAC: our brand new network drive based on a Raspberry Pi and DAC I-Sabre V3 ES9023 TCXO.
Moved to high definition dematerialized with RaspDAC. 100% Aluminium housing, DAC ES9023 24bit 192kHz TCXO, Raspberry Pi ! Here is an affordable solution for dematerialized reading assembled and tested in our workshops. A complete and ready-to-use network reader electronically, all you have to do is choose the software solution of your choice (Volumio, piCorePlayer, RaspBMC, Openelec...).
Get a very simple, high-end dematerialized audio player with a resolution of up to 24bit 192kHz in bit-perfect. Optimized for the sole purpose of offering the best of your music, Audiophonics integrates the new DAC I-Sabre V3 ES9023 24bit 192kHz equipped with a TCXO precision clock as well as a revised and corrected ground circuit and a new low LDO noise regulation of OS Con capacitors, this DAC I-Sabre V3 is the heart of the RaspDAC.
In addition, its advanced ATX power management system with different possible shutdown modes offers a high level of user comfort. It has all the necessary inputs and outputs, as well as an HDMI connector and an OLED display.
Illustration with an external 5V 2A regulated linear power supply not provided.
This RaspDAC has been designed to give you the efficiency of your Raspberry Pi in a high quality audio environment. Particularly elegant and discreet, it offers you the possibility of having a powerful and complete audio solution at an excellent quality/price ratio.
This 100% Aluminium housing has been specially designed to accommodate the Raspberry Pi and DAC Audiophonics I-Sabre V3 pair. In addition to giving the device a beautiful appearance, it also protects the components from shocks and dust.
Product type | Streamer |
Raspberry Pi 2 | Model B |
DAC | Audiophonics I-Sabre V3 ES9023 TCXO |
Supported sampling rate | Up to 24bit 192kHz |
Screen | OLED |
Case material | 100% Anodized Aluminium |
Connectivity | 1x Ethernet RJ45 4x USB-A 1x HDMI 1x Stereo RCA Output |
Power connector | Jack DC 5.5/2.1mm |
Dimensions | 160 x 140 x 50mm |
Display dimensions | 65 x 16mm |
Weight | 0.9kg |
Package | 1x RaspDAC 1x SDHC 8Go Card 1x Power supply |
