AUDIOPHONICS RaspDAC LTE I-Sabre V3 - Streamer Raspberry Pi & DAC TCXO
4.0 / 5
Reference : 11991
219,00 €tax incl.
182,50 € tax excl.
AUDIOPHONICS RASPDAC LTE ES9023
Sabre ES9023 DAC and Raspberry Pi 3
Raspdac LTE ES9023
The Raspdac LTE Raspberry Pi 3 comes back in a brand new version equipped with an I-SABRE V3 ES9023 converter.
Raspdac LTE ES9023
Dematerialized at your fingertips s
Switch to high definition dematerialized with RaspDAC LTE. Aluminium and Plexiglas housing, 24bit / 192kHz TCXO, Raspberry 3!
It is an affordable solution for dematerialized reading, assembled and tested in our workshops in France.
Complete and ready-to-use network drive electronically, you only need to install for the software solution of your choice (piCorePlayer, Max2Play...).
max2play
piCorePlayer
High-end audio player thanks to the DAC ESS Sabre ES9023 especially musical DAC ESS Sabre
This DAC I-SABRE V3 ES9023 is equipped with a TCXO 50MHz Ultra Low Jitter Precision Clock. The analogue stage has no active components and only a capacitor on its path. The result is an authentic listening without the usual caricature colours.
This RaspDAC includes advanced power management (ATX type) for the self-extinguishing of the software solution used. These functions are managed by a PIC and allow different extinguishing modes according to the needs (software or hardware).
Raspberry Pi
Version 3 Modèle B
Audiophonics DAC
I-Sabre V3 ES9023 TCXO
Design
Exclusive
design and reliable
Specially designed to allow you to have the efficiency of your Raspberry Pi in a high quality audio environment, it turns out to be as elegant and discreet so you can easily integrate it into your system.
The Raspberry Pi 3 and DAC I-SABRE V3 torque, integrated in an Aluminium and Plexiglas housing designed in our workshops, will prove to be particularly resistant and durable.
Raspdac LTE ES9023
Connectors
Raspberry Pi Outputs4x USB-A
1x Ethernet RJ45
1x Micro SD
1x HDMI
DAC ES9023 Outputs1x Stereo RCA
SNR110dB
Output level2V RMS
TCXO Clock Ultra Low Jitter50MHz
Audio formats supportedLPCM 2Ch
Dimensions102 x 169 x 50mm
Case100% Aluminium
Weight620g
Power supplyJack DC 5.5/2.1mm
Accessories1x power adapter 7V 3A supplied
InputMicro SD
InputRJ45
OutputUSB
OutputI2S LVDS via HDMI
DAC / ADC ChipES9023
Max sampling rate384kHz
bon produit
Ce lecteur réseau fonctionne très bien avec la solution piCorePlayer et un serveur LMS. Une question cependant, comment faire pour que la DEL du bouton poussoir de mise en route ne clignote pas de façon permanente?
This review has been posted for AUDIOPHONICS RaspDAC LTE I-Sabre V3 - Streamer Raspberry Pi & DAC TCXO
