AUDIOPHONICS RaspDAC I-TDA1387 - Network player Raspberry Pi & DAC TCXO
This RaspDAC network player from Audiophonics is based on a Raspberry Pi and DAC I-TDA1387 so you can enjoy your high-definition dematerialized audio files.
By buying this product you get 27 loyalty points
Reference : 11914
279,00 €tax incl.
232,50 € tax excl.
AUDIOPHONICS RASPDAC
DAC I-TDA1387 TCXO and Raspberry Pi 3 Network Reader
RaspDAC
Go to the high definition dematerialized with the RaspDAC. Case 100% Aluminum, DAC I-TDA1387 24bit / 192Khz TCXO, and Raspberry 3.0!
This new version now offers a dedicated hole for an infrared receiver, a micro SD card port, and of course the new Raspberry Pi 3.
A complete streamer, ready to use electronically, all you have to do is install a software solution. The Volumio system is particularly well suited for this purpose, allowing a simple installation with an intuitive and fluid interface, while ensuring high quality sound reproduction. It can be controlled via any connected device thanks to the web interface, it will perfectly match your RaspDAC. In addition, to work it is necessary to select under Volumio the corresponding driver, available in the "Downloads" tab of this page.
logo volumio
1-modifie.jpgh2-modifie.jpgraspdac-i-tda1387-thumbs1.jpgraspdac-i-tda1387-thumbs2.jpg
A high-end digital audio player ...
This evolution of our RaspDAC is now much faster thanks to the implementation of Raspberry Pi 3, has a hole for an infrared receiver, and a micro SD card reader offset, when it was difficult to access to the first version.
OptAUDIOPHONICS integrates the famous DAC I-TDA1387 24bit / 192Khz equipped with a TCXO precision clock. It takes the subjective advantages of the R2R DACs by providing a sound stability and a seating without the dissonance effects of the newer sigma delta DACs.
OfPlus, its advanced ATX power management with different possible shutdown modes offer a high level of ease of use. It has all the inputs / outputs necessary for its connection, its power supply (Jack DC5.5 / 2.1mm), an HDMI port, a micro SD card port and an OLED display.
Your Raspberry Pi in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an unbeatable value for money.
Raspberry Pi 3Model B
DACI-TDA1387 TCXP
DisplayOLED
<inputs/ Td>1x RJ45 / 4x USA-A / 1x Micro-SD Port
Outputs1x RCA Stereo
Power SupplyJack DC 5.5 / 2.1mm
Dimensions160 x 140 x 50mm
Display Size65 x 16mm
Weight0.9kg
Housing material100% Aluminum
Aluminum Case for DAC I-TDA1387 & Raspberry Pi 2/3
This 100% Aluminum case is designed to accommodate the Raspberry Pi 2/3 & Audiophonics DAC I-TDA1387.
RaspDAC housing
Supplied accessories:
To enable you to be directly operational, the player comes with an 8GB SDHC card, and its 7-9V / 2A power adapter.
InputRJ45
InputMicro SD
DAC / ADC ChipR2R LADDER DAC
Max sampling rate192kHz
This RaspDAC network player from Audiophonics is based on a Raspberry Pi and DAC I-TDA1387 so you can enjoy your high-definition dematerialized...
