Active SPDIF Splitter Optical Toslink 1 to 4
This SPDIF Optical Toslink splitter has one Optical Toslink connector at the input and four at the output. It allows you to broadcast the same Toslink Optical signal to 4 different devices at the same time. It is also compatible with PCM 2.0, DTS and Dolby-AC3 audio formats.
The AC adapter is included but requires the use of a US to FR 2-pin adapter (sold separately) for use on French power outlets.
| Specifications | |
| Product type | Optical Toslink splitter |
| Input | 1x Optical Toslink |
| Outputs | 4x Optical Toslink |
| Supported audio formats | PCM 2.0 DTS Dolby-AC3 |
| Max sampling rate | 192kHz |
| Supply voltage | 5VDC |
