[GRADE A] IEAST AUDIOCAST PRO M20 Streamer
-14%
Refurbished product - Grade A
The iEast Audiocast Pro M20 is a streamer that acts as a gateway to a truly connected audio system. It features a Wi-Fi connection as well as an Ethernet RJ45 port. It also benefits from Bluetooth 5.0 functionality for easy, stable wireless transmission.
Reduced price!
Reference : 21273
Limited special offer
49,00 €tax incl.
-14%
41,90 €tax incl.
34,92 € tax excl.
Torn cardboard packaging
iEast Audiocast Pro M20 Network Player WiFi AirPlay DLNA Bluetooth 5.0 24bit 192kHz
IEAST Audiocast Pro M20 picture
The iEast Audiocast Pro M20 is a streamer that acts as a gateway to a truly connected audio system. It features a Wi-Fi connection as well as an Ethernet RJ45 port. It also benefits from Bluetooth 5.0 functionality for easy, stable wireless transmission. The M20 can be controlled via the Audiocast APP Control application, which offers a wide range of settings. Multiroom operates in stand-alone or partition mode for greater flexibility. On the connectivity side, there's a toslink optical output and a 3.5mm stereo jack output for easy integration into any Hi-Fi installation.
Some streaming services available via IEAST Audiocast Pro M20
IEAST Audiocast Pro M20 for a connected Hi-Fi system
iEast Audiocast Pro M20: for a connected Hi-Fi installation
This M20 network player features a 2.4ghz Wi-Fi connection for a fast, stable connection. This makes it easy to access your audio files, whether stored on a smartphone, computer or NAS. It supports AirPlay and DLNA/UPnP protocols.
iEast Audiocast Pro M20: multi-room streaming
The M20, combined with other Audiocast products, can be used to set up a multi-room system with two operating modes:
  • Stand-alone mode: stand-alone mode lets you broadcast different playback tracks depending on your rooms.
  • Partition mode: partition mode enables all your speakers to play your music in sync.
Multiroom connection with IEAST Audiocast Pro M20
IEAST Audiocast Pro M20 Bluetooth feature
iEast Audiocast Pro M20: Bluetooth 5.0
The M20 features a Bluetooth 5.0 receiver chip supporting the SBC codec for stable, reliable wireless transmission of your music via a smartphone, for example.
iEast Audiocast Pro M20: Audiocast control APP
The Audiocast control app gives you access to all your streaming services, such as Spotify, Tidal, Deezer and Apple Music, as well as to numerous Internet radio stations. The application also offers a wide range of settings, including bass and treble equalization for personalized listening.
Audiocast Pro M20 overview
IEAST Audiocast Pro M20 overview
1Ethernet LAN port RJ45
2Toslink optical output
33.5mm stereo jack output
4Pairing button
5DC 5V power port
Product typeAudio streamer
InputsWiFi
Bluetooth
Outputs1x Toslink optical output
1x 3.5mm stereo jack output
WiFiWiFi IEE802.11 b/g/n 2.4GHz
BluetoothBluetooth 5.0
Supported Bluetooth codecSBC
Supported audio formatsAPE, FLAC, MP3, WAV, AAC, AAC+, WMA, ALAC, AIFF
Supported transmission protocolsDLNA, AirPlay, Spotify Connect, QPlay
Supported sample ratesUp to PCM 24bit 192kHz
Ethernet10/100M
Smart Home controlTCP/IP
Power supplyDC : 5V/1A
Dimensions86 x 84 x 21mm
Package1x iEast Audiocast Pro M20
1x 3.5mm jack to RCA stereo cable
1x 3.5mm jack to 3.5mm jack stereo cable
1x AC adapter and power cable
1x Remote control
InputWiFi
OutputJack 3.5mm
OutputOptical Toslink
DAC / ADC ChipNC
Max sampling rate192kHz
Remote ControlYes
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Refurbished GradeGrade A
[GRADE A] IEAST AUDIOCAST PRO M20 Streamer WiFi AirPlay DLNA Bluetooth 5.0 24bit 192kHz
Refurbished product - Grade A The iEast Audiocast Pro M20 is a streamer that acts as a gateway to a truly connected audio system. It features a...
