ATOHM SIROCCO 1-0 HiFi bookshelf Speaker 120W / 6 Ohm Black (Unit)
By buying this product you get 44 loyalty points
Reference : 11232
449,00 €tax incl.
374,17 € tax excl.
This SIROCCO 1-0 library loudspeaker will give you great sensations in terms of space, ventilation and definition. Due to its size, the grave register is reproduced with ease and unusual extension. Recommended for small parts, it can also be combined with the RAFALE V38S subwoofer to form a high quality 2 + 1 set.
Youyou will find in the attached documents 3 PDF files on the SIROCCO range of ATOHM.
Features:/ Strong>
  • Speakers: 2-way - Bass Reflex
  • Power Rating: 70Weff
  • Peak power: 120W
  • Impedance: 6 Ohm
  • Sensitivity level: 88dB / 2.83V / 1m
  • Frequency response: 50Hz - 25kHz
  • Switching Frequency: 3.5kHz
  • Boomer low medium: LD130CR04
  • Tweeter: SD20ND04F
  • Slope of filtering: 1st electrical order with timing of the tweeter
  • Case: MDF19mm
Packaging:
  • Finish: Satin black
  • Dimensions: 230x180x230mm
  • Weight: 8kg
  • Sold individually
