By buying this product you get 54 loyalty points
The HIFIMAN X100 Desktop 2.1 is perfectly designed to deliver high fidelity sound in a compact format.
The amplification part incorporates a dock with an analog input on 3.5mm jack.
You can connect a computer or a smartphone to get a high quality sound with a discrete, design, without distorting your interior, your office.
The two 1.5W satellites feature a bass-enhancing rear section for enveloping sound thanks to an internal membrane system.
The subwoofer subwoofer with an 8W power will easily support both satellites bringing a coherent sound for long hours of listening without auditory fatigue. Its compact and discreet design will make placement easy.
Main Features :
Entries:
3.5mm jack.
Satellite speakers:
Dimensions Speakers: 92 x 94 x 100mm.
Weight: 400gr for the 2 satellites.
Dock Support Amplifier:
Amplifier dimensions: 110 x 102 x 70mm.
Weight: 300gr.
Entere mains voltage: DC5V-2A.
Output power: 1.5W (on load 8 ohm).
Frequency response: 20Hz-20kHz.
Subwoofer:
power supply voltage: AC220V 50Hz 20W.
Output power: 8W.
Noise signal ratio: 90dB.
The Bundle contains:
