By buying this product you get 25 loyalty points
2-Way Bookshelf Speakers 80W 4-8 Ohm 90dB 48Hz-22kHz (Pair)
The Indiana Line Nota 250 X bookshelf speaker is a bass-reflex, rear ported model that offers great design quality and sound performance at an affordable price. This model is an excellent choice for medium-sized rooms up to 15m², both in a stereo system and in a home theater system.
The timeless shapes of the Indiana Line Nota 250 X emphasize Italian design expertise. The elegantly contoured side panels are finished with a durable and aesthetic vinyl coating. The technical solutions used for the Nota 250 X allow them to deliver an engaging sound with incredibly high dynamics for speakers of this size.
The Indiana Line Nota 250 X are relatively compact and light two-way speakers. They integrate a 26mm dome tweeter and a 135mm diameter bass-midrange driver. The bass-reflex port of this model allows these speakers to deliver deep and punchy bass.
The polypropylene diaphragm of the woofer provides a soft and warm reproduction of the midrange while ensuring a very good reproduction of the low frequencies. The dome tweeter, combined with a neodymium magnet and a radial rear chamber, is located in a specially shaped front panel, improving the dispersion of the high frequencies. The tweeter's crossover only uses air coils and film capacitors, allowing the speaker to deliver clear and accurate high frequencies.
Product type | Bookshelf speakers |
Number of ways | 2 |
Number of loudspeakers | 2 |
Bass-Reflex | Rear |
Loudspeakers | 1* Bass-Midrange Ø13.5cm driver, polypropylene cone 1* Tweeter Ø26mm, fabric dome |
Frequency response | 48Hz - 20kHz |
Snesitivity (2.8V/1m) | 90dB |
Crossover frequency | 2800Hz |
Amplification load impedance | 4-8Ω |
Recommended amplification power | 30 - 80W |
Recommended room size | < 15m² |
Dimensions (W*H*D) | 175*285*255mm |
Weight | 3.4kg |
Color | Black and walnut |
Quantity | Pair (2 speakers) |
Color | Walnut |
Color | Black |
Color | Wood |
Impedance (Ω) | 4 |
Impedance (Ω) | 8 |
Efficiency / Sensitivity (dB) | 90.0 |
Lowest frequency (Hz) | 48 |
Highest frequency (Hz) | 22000 |
Power (W) | 80.0 |
Speaker type | Passive |
Speaker form factor | Bookshelf speaker |
