ELFIDELITY AXF-107 Power Filter PCI Express / PCI Express 16x
The AXF-107 module from Elfidelity is a switch mode power supply filter for computers connected in PCI Express or PCI Express 16x and designed to provide cleaner power to all connected cards (sound card, interfaces, GPU...).
Reference : 14182
52,90 €tax incl.
44,08 € tax excl.
Shipping date: 27-05-2025.
Elfidelity AXF-107
Elfidelity AXF-107 Filtre d'Alimentation PCI / PCI Express
Developed by Elfidelity, this product provides a HiFi solution to the noise problem of switched-mode power supplies equipping the vast majority of computers. Its careful architecture includes muRata and TDK inductors to reduce EMI interference, Sanyo SVPF Polymer capacitors, AVX Tantalum capacitors, WIMA MKP-10 capacitors or EVOX MMK Metal capacitors. Two groups of RGB LEDs can be controlled independently, with 7 colors available. Moreover, its installation is very simple since no driver is required.
Product typeComputer power filter
ConnectivityPCI Express (PCIe) and PCI Express 16x : reversible PCB
Status LED
InputPCI Express
OutputPCIe
4 reviews
Ottimo risultato
L'ho integrata in un contesto importante di pc alimentato in lineare con 45 ampere sui 15Vm, scheda usb AFX100, Ian canada linearpi mkII ed ultra condensatori per schda usb e per dac.
Montato a monte anche della scheda video l'intero pc già ottimizzato ha dato il risultato sperato.
Lo consiglio. Ne ha guadagnato anche il risultato video.
Mai avrei pensato che axf107 unito a afx100 potesse rendere così tanto.
This review has been posted for ELFIDELITY AXF-107 Power Filter PCI Express / PCI Express 16x
Ce filtre ne joue pas que dans la déco !
Le filtre de puissance AXF-107 est monté sur une ASUS Maximus Z690 HERO avec une JCAT USB EX sans jumper.
Pour obtenir le meilleur rendu sonore, le filtre a été placé sur le bus PCIE du haut, cela semble logique, puisque tout ce qui se trouve en dessous bénéficie du filtre. Un test avec la AXF-107 dans le bus PCIE du bas et JCAT en haut n'apporte aucune amélioration sur cette carte mère ASUS.
Un gain supplémentaire de qualité sera encore obtenu en éteignant les leds de la AXF-107, ceci en inversant les 2x3 dips, mais dites adieu aux effets lumière tant convoités mais tellement nocifs à l'audio !
Un autre test avec 2 AXF-107 (bien placées) est prévu ..
recommandé par le constructeur..
Testé adopté!!
Monté sur un PC tout neuf avec MATRIX Element H, ce n'est pas très flagrant mais, comment dire, le silence est bien posé, la fuguasse distorsion ou coloration tout en haut des aigus n'est plus, je note aussi un mieux pour le dynamisme qui aide à l'équilibre du morceau joué.
Carte enlevé puis remis puis enlevé puis remis et laissé car je dirais que ce filtre aide au rendu naturel du son.
Pas mal du tout ce filtre.
Eric W
Works fine, especially in lower frequencies. Great value for money. Lowers noisefloor (below -50db) neatly. Efficient reduction of 50Hz. hum. Just a clever product, Problemless, easy installation.
 (4)
The AXF-107 module from Elfidelity is a switch mode power supply filter for computers connected in PCI Express or PCI Express 16x and designed to...
