Thisamplification modulehas been designed to be housed in PCs dedicated to audio or HTPC.
Based on the architecture </ strong> of the famous brand Texas Instrumentsit exploits a chipTPA3116D2to provide power up to 2 x 15Watt at 4Ω.
Capable of receiving an external signal via 3.5mm Jackor via an internal connector on the PCB, it will adapt to all your needs.
Note: When using your PC's power supply, remove the jumper located behind the 3.5mm jack to avoid mass problems and take full advantage of the sound quality of the card.
Features:/ Strong>
Channel Output Power:
Total Harmonic Distortion Rate:
Rate of DIntermodulation istorsion (SMPTE):
