Adapter DAC AL5686 Male Lightning to Female Jack 3.5mm 32bit 384kHz
This TC35C DD adapter for smartphone is composed of a male Lightning connector and a female 3.5mm jack. It also includes a Realtek AL5686 DAC for efficient conversion of the audio signal for a clear and precise reproduction, while supporting high resolution streams, up to PCM 32bit 384kHz. The robust connector body is made of CNC machined aluminum. Its practical "T" shape allows for a compact design.
Be sure to plug in the headphones before connecting the DAC to the Apple device.
Product type | Adapter and DAC |
Connectors | 1x Male Lightning 1x Female Jack 3.5mm |
DAC Chip | Realtek AL5686 |
Supported sampling rates | PCM up to 32bit 384kHz |
Frequency response | 20Hz - 20kHz |
Output power | 30mW @ 32Ω |
Dynamic range | > 110dB |
THD+N | < -92dB |
SNR | > 120dB |
Dimensions | 16.6 x 16.2 x 9.6mm |
Weight | 3.5g |
Input | Lightning |
Output | Jack 3.5mm |
DAC / ADC Chip | AL5686 |
Max sampling rate | 384kHz |
Color | Blue |
Color | Black |
Networking | No |
Remote Control | No |
Contacts Material (Connector) | N/A |
