Portable DAC Adapter ES9219MQ/Q USB-C to Jack 3.5mm 32bit 384kHz DSD256 MQA
The iFi Audio Go Link is the perfect accessory for connecting headphones or earphones to a device that does not have a Jack 3.5mm headphone output, such as a recent smartphone. It also allows devices with a headphone output to enjoy better sound thanks to the built-in high-quality DAC and headphone amplifier.
The Go Link consists of a USB-C male input and a Jack 3.5mm headphone output. Each part is clad in a strong and light magnesium alloy body. Between the two, a 6cm flexible cable allows for convenient use while reducing mechanical stress on the connectors and connected devices. In addition, the cable incorporates individually insulated, silver-plated copper conductors, ensuring excellent conductivity for perfect signal transmission.
The core of the Go Link houses a powerful ES9219MQ/Q DAC from ESS Technology, taking advantage of the manufacturer's 32bit HyperStream III architecture.
In addition to this DAC, the Quad DAC+, Time Domain Jitter Eliminator and a dedicated clock circuit allow to reach a very low level of distortion to reveal a clear and dynamic sound. The DRE (Dynamic Range Enhancement) technology allows an adjustment of the analog gain to minimize THD and crosstalk.
The Go Link is Hi-Res Audio certified and supports high-resolution audio streams, up to PCM 32bit 384kHz and DSD256, for rich, detailed and dynamic sound reproduction. It can also decode MQA (Master Quality Authenticated) files for a sound reproduction as close as possible to the original studio recording. An LED indicator allows you to quickly and easily identify the type of stream being played.
"The most important thing to remember about this little iFi GO link is that it's a sure bet for anyone looking to considerably improve the sound quality of a laptop or smartphone for listening with headphones or wired IEMs."
| Specifications | |
| Product type | Portable DAC |
| Input | 1* USB-C |
| Output | 1* S-BAL Jack 3.5mm headphone output |
| Supported sampling rates and formats | PCM up to 32bit 384kHz Native DSD up to DSD256 MQA |
| Output power | ≥ 1.5V / 70mW @ 32Ω 2V / 14mW @ 300Ω |
| Output impedance | < 0.4Ω |
| SNR | ≥ 125dBA (2.05V) |
| Dynamic range | ≥ 122dB(A) @ 0dBFS |
| THD+N | < 0.0004% (1.27V @ 32Ω) |
| Frequency response | 10Hz - 80kHz (-0.5dB) |
| General | |
| Consumption | Aucun signal : ~0.2W Signal max : ~1W |
| Dimensions (L*P*H) | 135*12.6*7.6mm |
| Cable length | 6cm |
| Weight | 11g |
| Input | USB |
| Output | Jack 3.5mm |
| DAC / ADC Chip | ES9219MQ/Q |
| Max sampling rate | DSD256 |
| Max sampling rate | 384kHz |
| Max sampling rate | MQA |
| Color | Gray |
| Networking | No |
| Remote Control | No |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Gorazd K.
