MOONDROP ECHO A USB-C to 3.5mm Jack Adapter
The Moondrop Echo-A is a compact, high-performance USB-C to 3.5mm jack adapter designed to deliver a high-resolution audio experience with ease. It incorporates a DAC/headphone amplifier chip capable of supporting sampling rates up to PCM 32bit 384kHz.
Reference : 20602
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 05-08-2025.
Moondrop Echo-A Adapter DAC Headphone Amplifier USB-C to Jack 3.5mm 32bit 384kHz
Photo of MOONDROP ECHO A DAC adapter
The Moondrop Echo-A is a compact, high-performance USB-C to 3.5mm jack adapter designed to deliver a high-resolution audio experience with ease. It incorporates a DAC/headphone amplifier chip capable of supporting sampling rates up to PCM 32bit 384kHz. Thanks to its plug and play compatibility with many operating systems via the UAC 2.0 protocol, the Echo-A is extremely easy to use. It guarantees clear, precise sound reproduction, with a THD+N of just 0.01% and an SNR of around 100dB. Designed primarily for use with smartphones, it can also answer calls using the OMTP protocol.
MOONDROP ECHO A highlights
Product typeUSB-C to 3.5mm jack adapter / DAC
Connectors1x USB-C male
1x Jack 3.5mm female
SNR100dB (A-WT)
Dynamic range102dB (A-WT)
THD+N0.01%
Phone callsOMTP protocol via 3.5mm jack
OS compatibilityWindows, MAC OS, Android, IOS
Package1x Moondrop Echo-A
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate384kHz
ColorSilver
ConnecticMale & Female
ConnectorUSB-C
ConnectorJack 3.5mm
Remote ControlControl app
MOONDROP ECHO-A Adapter DAC Headphone Amplifier USB-C to Jack 3.5mm 32bit 384kHz
The Moondrop Echo-A is a compact, high-performance USB-C to 3.5mm jack adapter designed to deliver a high-resolution audio experience with ease. It...
